XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
      03-17-2016, 06:42 AM   #1
BMW_Viking
BMW_Viking's Avatar
Drives: BMW X1 2.0xdrive 2010
Interior light LED
When I change the regular light bulbs in the interior (trunk etc) with LED there is no light. Do these things need to be coded? Thanks
      03-17-2016, 09:13 AM   #2
vstolpner
Drives: 2019 F39 X2 m35i
No coding required. You might have the bulb in backwards. LEDs are directional so if you put it in reversed it won't light.
Alternatives: your LEDs are broken, or you blew a fuse installing the light bulbs. Check the LEDs with a 12V source and make sure your fuse is fine by putting the factory bulbs back in.
      03-17-2016, 11:17 AM   #3
BMW_Viking
BMW_Viking's Avatar
Is it any wonder why I love this forum. Problem solved! Just had to reverse the two LED bulbs I had tried so far, then install the rest by trial and error.
      03-17-2016, 05:54 PM   #4
walendvay
Drives: '11 F25 28i; '13 E84 35i
I found that I needed "error free" bulbs for the map lights and the cabin light (three bulbs up front). FYI.
for those that don't know, an error free bulb has a resistance across it to emulate the current consumption of a traditional incandescent bulb.
Tags
interior light
xbimmers
