BMW CIC Navigation Europe (West)PREMIUM Road Map 2016-1
02-28-2016, 12:26 PM | #1 |
Rep 23
BMW CIC Navigation Europe PREMIUM Road Map 2016-1 downloaded on a SanDisk Cruzer Blade 32gb memory stick.
This is for Sat Nav systems with only one DVD slot All you need is a FCS code matched to your chassis number. Which can be obtained from one of the coders on here. Much easier to use than downloading several PDF files on to your own memory sticks I instead of 3. Please make sure that your system is the Premium one. £30 posted. |
02-29-2016, 09:02 AM | #2 |
Rep 405
Hi bud how much will one of the coders charge for the FSC code?
I have a pro sat nav (e91 325d m sport 61 plate) will this work on mine? Thanks x |
02-29-2016, 05:12 PM | #3 |
Rep 23
There were some posts on here which had a link to ebay for people able to send you a FCS code based on your chassis number, unfortunately I can not find the link.
From what I can remember it is around £18. I believe BMW will charge you around £250 for the update. If you go into your Sat Nav system you can find out which version you have, if it says Premium I have the one you want. |
02-29-2016, 05:46 PM | #4 |
Rep 133
I have the tools. give me a shout first and i will try and sort you out. Not tried it for the 2016 maps but sure I can get an update
