01-18-2016, 09:38 PM | #1 |
Rep 554
Brrrrrrrr.
It's 12 degrees outside. Perfect time to wash a couple cars! Right? So I cranked up the heat in the garage and used the waterless wash technique. At least it makes me feel better. I literally lose sleep over dirty cars. It's a sickness.
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S |
01-19-2016, 08:38 AM | #2 |
Rep 886
Then mine is going to keep you up nights. Winter and no garage = not clean.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/BimmerTech amp, Enhanced BT
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi |
01-19-2016, 09:19 AM | #3 |
Rep 554
OMG! I'm going to have to report you to the ASPCA! (American Society for the Prevention of Cruelty against Automobiles.) I'll give you a week. If it's not groomed shiny and fed with warm gas I will come and take it away from you. Bad boy, BAD! 😜
01-19-2016, 10:07 AM | #4 |
Rep 886
Worst part is, that's one morning's drive.
01-19-2016, 10:10 AM | #5 |
Rep 554
At least its a new car. In decades past you could probably "hear" the rust forming!
The Stable
01-19-2016, 05:55 PM | #6 |
Rep 5,102
I envy your garage.....
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
01-19-2016, 09:36 PM | #7 |
Rep 8,942
What wash do you use? Just picked up chemical guys haven't tried it yet. May just go to dad's house though he has heated garage w a drain in the floor for winter washing.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
01-20-2016, 02:55 PM | #8 | |
Rep 554
I have used several different washes. Chemical Guys is fine. I have used several different brands, HD, Blackfire, DP, Optimum, Griots, etc. They all work basically the same. The trick to using any of them is proper technique. I have a bucket half full of water with a few squirts of waterless wash to add some lubrication and dirt lifting. Pre spray the panels of the car with the bottle of wash. You need to have a lot of towels. I fold them in quarters and soak them in the bucket. Then use them to wipe the panel, always in straight lines and curl the towel as you pull it across the panel so you are not grinding in the dirt. Then fold, use a clean side and make a second wipe. Continue using clean sides of the towel always. After I get eight swipes out of a towel I toss it aside and get another clean towel, soak it and repeat. I never use a dirty towel twice. I do a panel at a time. Then I use a soft waffle weave drying towel to dry the panel. It works well. I just did my Touareg TDI a couple days ago. It's freezing outside with snow on the ground but I can't stand a dirty car. I just wish it would last longer!
The Stable
01-20-2016, 03:44 PM | #9 | ||
Rep 8,942
2022 Macan S
01-20-2016, 05:35 PM | #10 | |
Rep 554
Yes, I agree, a late fall application of sealant is part of my modus operandi, too. A sacrificial barrier. At least it makes me feel better. Another note, I have one of these buckets which are great. Not cheap ($50-60 but sometimes go on sale) but worth it. I like the screw on lid that allows me to keep the water I mix up clean and I can save it a few weeks. There is also a grit guard and roller wheels. Comes with a pad, too, so you can use it as a stool. A nice garage toy!
The Stable
01-20-2016, 06:26 PM | #11 | ||
Rep 8,942
2022 Macan S
01-20-2016, 07:02 PM | #12 |
Rep 554
The Stable
01-21-2016, 10:58 AM | #13 |
Rep 8,942
With proper supervision, of course! My father once caught me about to spray his entire 500E (the nasty one that was built w Porsche) with wheel cleaner because I like to watch the dirt dissolve and rinse off when he did it to the wheels. Was smart enough, however, to scream "Dad, mom is being baaaaad" with all the power my little 8 year old lungs could muster when she scraped the garage and tried to use soft scrub on her car to get the paint off before he found out.
2022 Macan S
01-22-2016, 02:04 PM | #14 | |
Rep 554
The Stable
01-22-2016, 02:59 PM | #15 | ||
Rep 8,942
A few years back I broke up with a girl over car maintenance. Her clear coat was all jacked up, asked her what happened. "I used the sponge from the kitchen, you know the one that says no scratch on the scrubber side." It was all over after that - date dumb yes. Marry it no.
2022 Macan S
01-22-2016, 04:20 PM | #16 | |
Rep 554
The Stable
01-22-2016, 04:52 PM | #17 | ||
Rep 8,942
2022 Macan S
