11-18-2015, 05:13 AM | #1 |
Rep 852
Requests for DIYs
Just thought it would be nice to make a request thread for those things we would like to see DIYs on.
For example, I don't recall seeing a DIY on: Fuel filter replacement. Coil Pack / Spark Plug replacement. Please add more as you think of them.... |
12-29-2015, 11:59 AM | #4 |
Rep 637
Drives: Nissan GTR / F06 M6
Its pretty easy. I have attached a little picture of what you need to remove to remove the DME's.
Basically remove the plastic Engine cover (just pull up it snaps off). Then remove those items in the picture I have the arrows to. The ECU assembly locks in similar to how the engine plastic cover is. You just pull it off the rubber grommet holes. Do the same for the other side. Make sure you zip-tie those coolant lines up so it doesn't leak everywhere. |
M5averick16.50 |
01-25-2016, 01:58 PM | #6 |
Rep 70
Jb4 + bcm installation with putting the wires through the drivers side.
Terry's guide/pictures are for n63.
01-28-2016, 02:04 PM | #7 |
///M Driver
223
Rep 268
Drives: 2018 First Edition M5
I see a lot of people including myself interested in upgrading/ replacing interior trim pieces just to change things up. If somebody knows where a DIY guide of removing and installing those interior trim pieces that would be very helpful. Thanks!
02-06-2016, 03:44 PM | #8 |
Rep 2,514
Front and Rear Brake pad replacement
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo ?22 Tesla Model Y Performance Midnight Silver/White |
04-28-2016, 08:07 AM | #9 | |
Command Sergeant Major of the Army
141
Rep 639
2018 F82 M4 ZCP
2015 F13 M6 ZCP (gone) 2013 F10 M5 (gone) 2008 E90 M3 (gone) Last edited by Lerxst M4; 04-28-2016 at 08:42 AM.. |
04-28-2016, 08:12 AM | #10 | ||
Rep 501
2016 McLaren MSO 570S | 2018 Ford Raptor | @alpha7even
04-28-2016, 08:17 AM | #11 |
Rep 637
It is best practice to disconnect the battery. However, I did not and have not had any issues disconnecting them with the battery connected (I have done it multiple times as well).
04-28-2016, 08:47 AM | #12 | |
Rep 637
The wire for the obd can be tucked under the plastic covers where I have the line drawn. UPDATE: Picture with the intake off. Last edited by DATM3; 04-28-2016 at 09:28 AM.. |
sqeezed98.50 |
04-28-2016, 08:52 AM | #13 |
Rep 637
The trim pieces are actually pretty easy to remove. Most all of them only push on. Get a credit card or plastic prop tool and stick it between the leather and trim piece. Once you have a little leverage pull against them and they will pop out. After they pop out just disconnect any plugs if the trim has any electronics on them.
04-28-2016, 02:10 PM | #14 | |
141
Rep 639
On the coolant loss, if careful will a lot drain out (as opposed to not being careful and losing more). How much needs to be topped off (generally) if done carefully? Thanks again!
2018 F82 M4 ZCP
2015 F13 M6 ZCP (gone) 2013 F10 M5 (gone) 2008 E90 M3 (gone) |
04-28-2016, 02:15 PM | #15 | ||
Rep 637
04-28-2016, 04:15 PM | #16 | |
Rep 1,625
04-28-2016, 04:59 PM | #17 |
Rep 637
Yea, i can help. You wanna bring it down tomorrow sometime?
05-24-2016, 05:29 PM | #18 | |
141
Rep 639
Thanks!
2018 F82 M4 ZCP
05-24-2016, 06:31 PM | #19 | ||
Rep 637
05-24-2016, 06:32 PM | #20 |
Rep 637
Here is the picture.
05-24-2016, 06:40 PM | #21 | |
141
Rep 639
2018 F82 M4 ZCP
