10-22-2015, 10:13 AM | #1 |
Rep 167
catless DP install
Hi,
Does anyone have a catless DP install instructions for n55 335i? i found instructions for 235i, is it the same as 335i? Thank you |
10-22-2015, 10:59 AM | #2 |
Rep 396
Drives: 2014 335i M Sport, 2004 .:R32T
It's pretty much the same. That's the instructions I used. Once your under the car it's pretty self explanatory and will be a breeze.
10-22-2015, 11:05 AM | #3 |
Rep 167
10-22-2015, 11:18 AM | #5 |
Rep 167
10-22-2015, 11:18 AM | #6 |
Pace Car Driver
1548
Rep 3,164
10-22-2015, 12:17 PM | #9 |
Rep 167
10-22-2015, 04:05 PM | #11 |
Rep 167
10-23-2015, 09:20 AM | #12 |
Rep 4,323
Make sure your clamp from DP to exhaust isn't too rusted - mine was a wreck and it wasn't included in kit.
Also note that some years are different (ie, after 2013 I think larger DP diameter).
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
10-23-2015, 09:50 AM | #13 |
Rep 167
No rust on my car as its 2015 with 1k miles , and yes the pipe is 4", just got it yesterday...
10-23-2015, 09:54 AM | #15 |
Rep 167
10-23-2015, 10:04 AM | #16 |
Rep 1,425
That's not bad at all. It's been a long time, but I remember it being a real pain on my G35 coupe. Then again, there were two downpipes.
10-23-2015, 10:08 AM | #17 |
Rep 167
right, my car is only 1 downpipe and from what i read it doesn't seem that bad, plus using a lift instead of ramps will be much easier..
10-23-2015, 10:28 AM | #18 |
BimmerPost Supporting Vendor
4918
Rep 115,980
10-23-2015, 10:28 AM | #19 |
4918
Rep 115,980
10-23-2015, 10:41 AM | #20 |
Rep 167
10-23-2015, 11:28 AM | #21 |
Rep 254
Drives: E30 M3 & 325ic-F30 335i Xdrive
They sell special 22MM O2 sensor wrenches and sockets. After you un install the DP, you can use an adjustable sliding wrench or a 22MM wrench but you can risk stripping the nut. I would just by the O2 sensor socket.
10-23-2015, 11:40 AM | #22 |
Rep 167
thanks, will check autozone to see if the have those in stock..
