BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Aisin transmission performance
      10-15-2015, 12:56 PM   #1
KGB_123_99
Drives: '17 330ix M-Sport, '09 528ix
Has anyone had the opportunity to compare the transmission in the new X1 to the ZF8? How is the programming and shift speeds?
      10-15-2015, 04:12 PM   #2
Ganxxta
Germany
85
Drives: F32 4er Coupé
I'm afraid its inferior just by comparing official BMW data for both, the ZF8 usually is rated faster than manual while using less fuel.
The Aisin however is exactly the opposite, its rated slower than manual and is using more fuel.
(comparing german versions as you guys won't have the manual in the X1 as far as I know)
However after watching some reviews some say its fast and smooth and shifts at the right time to the right gear, so it can't be that bad.
      10-15-2015, 07:37 PM   #3
JoeyO
Drives: silver car
Aisin is Japanese and ZF is German, right?
      10-16-2015, 07:32 PM   #4
KGB_123_99
Yup
      10-17-2015, 09:02 AM   #5
JoeyO
Drives: silver car
Are there any American transmissions manufacturers?
      10-17-2015, 01:14 PM   #6
r999
Drives: 550i
Autos aren't really better than manuals for fuel economy or for performance. It's just that things can be arranged to make them look that way. A typical way to make an auto look better than the manual on the same car is to give it slightly lower overall gear ratios than the manual in the first few gears to improve initial acceleration, and higher ratios in the top gear or two to give it better fuel consumption at motorway speeds. Then it appears to be better on both measures. That, of course, leaves a larger gap (step) in the gear ratios somewhere, which harms acceleration in the upper speed ranges, but as nobody ever quotes figures in that range, few people notice. This is how my 550i auto is configured compared to the manual. The new X1, on the other hand, appears to use the same overall gearing for both manual and auto, so no flattery is taking place.
As for the new X1, in German spec:
- the 0-100 km time is identical for manual and auto on the sDrive18i, the sDrive 18d, and the xDrive 20d;
- the top speed is identical for manual and auto on the sDrive 18d and the xDrive 20d;
- the fuel consumption is identical for manual and auto on the xDrive 18d and the xDrive 20d.
- while the auto performs a little worse than the manual in a few other cases. But viewed altogether, the differences are not significant enough to justify your claim that the Aisin is worse than the ZF.
      10-17-2015, 01:47 PM   #7
Ganxxta
Germany
85
The sDrive 18i will get a 6 Speed Auto, so no comparison to the ZF8 possible, maybe due to less gears it will be lighter which might help the overall package.
The xDrive 20d has a rated fuel consumption of 4.9l against 4.8l in the manual
But in general you are right that it should not be worse than the manual, also considering that with auto there is additional weight.
I didn't get the opportunity to drive one myself yet, however the ZF8 that I have is pretty good I must say.
      10-17-2015, 02:30 PM   #8
r999
Drives: 550i
Not in the German X1 brochure it doesn't.
Verbrauch, Kombiniert:
manual: 5,1 - 4,9
auto: 5,1 - 4,9
      10-17-2015, 03:02 PM   #9
Ganxxta
Germany
85
https://www.press.bmwgroup.com/deuts...hmentId=331820
Page 67
      10-17-2015, 03:59 PM   #10
r999
Drives: 550i
Then I suggest (since you are in Germany and I am not) you tell BMW that the fuel consumption figures in the German price list contradict those in the German brochure. Perhaps they have caught a little touch of VW disease?
      10-17-2015, 06:45 PM   #11
Ganxxta
Germany
85
Haha might be
The European fuel consumption figures are totally unrealistic anyway, so 0.1l more or less doesn't matter much. The only indication that this list shows for the 20d is that the auto uses less in the city and more on the highway than the manual (which is weird, since 8 gears should have at least 1 overdrive extra long gear ratio for highway speeds compared to the 6 speed manual).
Next week is the official premiere at my dealer so I want to try to have a test drive in the X1 to be able to compare it to the ZF8 in my F32.
      10-17-2015, 07:33 PM   #12
r999
Drives: 550i
I am not much concerned about fuel consumption either: if I were, I wouldn't drive a 550i.
But please do let us know what you think of the quality of the gearbox after you have tried it.
      10-27-2015, 12:35 AM   #13
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
Having test driven the X1 xDrive20d with this transmission, and because I currently own a F20 M135i with the ZF8AT, I can confirm the Aisin transmission is very smooth, and changes rapidly. I didn't test it as a high performance auto, as per the ZF, because the X1 isn't that sort of car, but I reckon most owners will be very satisfied with the Aisin.
BMW F22 M240i; F48 X1 25i, BMW F20 M135i
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
      10-27-2015, 12:28 PM   #14
r999
Drives: 550i
I too drove that model this week and I agree entirely with your view. (I'm not so keen on the steering or the road noise, though.)
      11-13-2015, 04:49 AM   #15
ron_jeremy
ron_jeremy's Avatar
Norway
513
Drives: 13' F25 X3 20d & 16' i3
I agree.
However, given the choice, i'd pick the ZF.
It's more "reliable" and changes a tad faster imo, but it's a close race.
3 series: E30: 89 325i, E36: 92 325iC, 94 320iC, 96 320i Convertible, 94 320iaC, E46: 99 320ia, E90: 06 318i Le mans, E91: 07 318dt
5 series: E39: 97 520ia, 01 530Dat, E61: 09 520Dat
X series: E83 05 X3 2.0d, E84 10' X1 2.0 X-drive DA, F25 13' 2.0da X-drive.
      11-15-2015, 11:16 PM   #16
ttimbo
ttimbo's Avatar
282
Yesterday, I had the opportunity to drive the new 3 series 330 back to back with the X1, both with auto transmissions.
I felt the Aisin actually had smoother shifts that were just as fast as the ZF, including when using the paddles; they're both great A/Ts, I reckon.
As to reliability, it's a bit too early to tell, as the Aisin has only been in use since 2013, but it does have a fairly wide range of automotive customers in addition to BMW: Chevrolet; Lexus: Toyota: Volvo, to name a few.
      11-16-2015, 12:34 AM   #17
ShinySteelRobot
iPhone/iPad Developer
ShinySteelRobot's Avatar
Drives: BMW 650i
Other types of Aisin transmissions have been used in Porsches too, so their transmissions can't be that bad.
FWIW, I doubt 95% of drivers would be able to tell any difference in real-world driving between the ZF and the Aisin.
      11-16-2015, 02:04 AM   #18
PF1
Drives: F48 X1 xDrive25i M Sport
I was quite happy and impressed with the Aisin 8AT on my test drives. I think without back to back drives with a ZF car it would be hard to tell the difference. The Aisin is way ahead of my Merc's slow, clunky and dumb 7G-DCT. My only gripe with the X1 gearbox is having a mechanical shifter rather than an electronic one. I reckon since Toyota and Lexus are using this gearbox it can't be too bad, given their brands' reputation for reliability.
      11-16-2015, 02:34 AM   #19
ttimbo
ttimbo's Avatar
282
Yes, Aisin has been around for a good while, with units including its longitudinal 8AT in a number of high performance cars. Lexus/Toyota is renown for its supply chain rigor, so I'm not worried. The physical shifter (vs ZF electronic) is something you'll notice only if you have another car with electronic shifter.
      07-07-2019, 09:58 AM   #20
00max00
Drives: BMW X1 - option loaded
Haha might be
It is actually pretty conservative in fuel consumption figures for at least the US spec x28i. The official is 31 mpg highway, I am getting 35 mpg consistently. On light traffic and at moderate cruise speed, it is getting 38 mpg. There's no manual here so I have nothing to compare it to.
      07-08-2019, 02:13 AM   #21
ttimbo
ttimbo's Avatar
282
Originally Posted by Beagler View Post
Can anyone confirm which 8 speed auto will be in my newly ordered x1 2ltr Petrol m sport AWD Please, Aisin or ZF, transverse or Longitudinal.
It will be the Aisin, in transverse configuration. The ZF 8AT is not fitted to any F48 X1 model
      07-08-2019, 02:17 AM   #22
ttimbo
ttimbo's Avatar
282
Haha might be
Over nearly 60,000km, our X1 25i AWD (same as 28i in US model designation) has averaged 8.2L/100km
xbimmers
