10-11-2015, 07:30 AM | #1 |
Rep 348
Drives: '20 330i MSport
JB4 Map 2 or Map 5??? Suggestions
Hey guys! Like the title says im just trying to get some opinions on weather people like Map 2 or Map 5 better. The shop that installed my down pipe and JB4 said i could run either one but map 2 should do just fine.
My mods: BMS Intake Eisenmann Race exhaust ER dp JB4 Also is there anyway possible for my JB to delete my Cel code from my intake permanently. I keep getting a P00BD code which i believe is for "mass air flow" Thanks in advance! Chris
2020 330i M Sport 2017 X4 M40i *Retired* 2014 F30 335i M Sport *Retired* |
10-11-2015, 07:53 AM | #2 |
Pace Car Driver
1548
Rep 3,164
Our 435i has a catless DP and a JB4.
Has flex fuel wiring but no EWG wiring connected. I honestly felt no difference going to Map 5 from Map 2. Leaving on Map 5 now just because it's probably best. Pull some logs and let the guys at BMS tell you which is better. I'm guessing Map 5 will be the answer. I thought Terry / BMS posted a fix for the intake CELs? |
10-11-2015, 03:49 PM | #3 |
Rep 1,359
Map 2 will target approx 14psi, map 5 will target between 11-17psi based on octane and conditions so run some logs and see which one looks better. Map 5 is probably the safer option but based on your mods I cant see why you couldn't run map 2. I always felt that map 2 pulled harder than map 5 on my old N54.
10-12-2015, 07:40 AM | #4 | ||
Rep 348
10-12-2015, 02:54 PM | #5 |
BimmerPost Supporting Vendor
24201
Rep 190,807
Both maps are fine. I suggest you try both for a week each and decide which one you like better. I feel map 5 is smoother but it is not consistent.
Map summary Map 0: JB4 disabled Map 1: Additive target, around 4psi over stock. Map 2: Additive target, around 6psi over stock. Suggested for those with 93 octane and bolt on modifications. Also good for small E85 mixtures. Map 3: Progressive methanol mapping, absolute target of 11-20psi based on meth flow, meth additive setting, and average ignition values. Map 4: Stock performance with JB4 active for logging only. Map 5: Autotuning map, absolute target of 11-17psi based on octane and conditions. Map 6: User definable absolute target map. Suggested for troubleshooting by professionals only. Map 7: Race gas map. Absolute target of 18.5psi. Requires straight unleaded race gas.
10-12-2015, 04:11 PM | #6 | |
Rep 348
10-12-2015, 06:06 PM | #7 |
Rep 939
10-13-2015, 02:26 AM | #8 |
Rep 2,358
I never use map5 - feel inconsistent. Even on the same tank of gas.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
10-13-2015, 07:40 AM | #9 | |
Rep 348
10-13-2015, 10:22 AM | #11 | |
Rep 348
10-13-2015, 12:11 PM | #13 | |
4918
Rep 115,980
Mike |
10-13-2015, 05:08 PM | #14 | |
Rep 348
10-13-2015, 05:52 PM | #15 | |
Pace Car Driver
1548
Rep 3,164
Which means, even if you didn't want to, you now HAVE TO buy the data cable. |
10-14-2015, 07:46 AM | #16 | ||
Rep 348
What should the latest firmware be?
10-14-2015, 10:01 AM | #17 | |
Pace Car Driver
1548
Rep 3,164
Double check me but I think this is the latest and greatest. Assuming you're EWG. I was scratching my head as well when I first installed the JB4. Upgrading the firmware should normal everything up for you. Last edited by G30 B58; 10-14-2015 at 11:26 AM.. |
10-14-2015, 07:55 PM | #18 | ||
Rep 348
10-14-2015, 09:10 PM | #19 |
Pace Car Driver
1548
Rep 3,164
10-15-2015, 07:33 AM | #22 |
Rep 348
According to bimmer.work my production date is 3/18/14. So I guess I am EWG and could update to the latest firmware.
