09-22-2015, 11:06 PM | #1 |
Rep 2,358
Intercooler pressure loss
Hi
I recently installed my IC and if I compare logs it seems I loose 1.7psi @ 6500rpm compared to stock. Is this to be expected - 1.7 is a lot!!? (please ignore the bad log with stock IC, its a log from the process of tuning DB)
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
09-23-2015, 12:30 AM | #2 |
Rep 863
Harkes,
From the logs, it looks like you may have a small boost leak based on the boost curve. Easiest way to find a boost leak is to get a spray bottle and fill it with soapy water. Spray any connections that can leak (intercooler connectors, silicone/rubber couplers etc). Don't spray anything electronic like the MAP sensor as that can potentially damage the sensor. Rev the car. If there are any leaks, you will see a constant stream of bubbles from the leak area. Since you recently changed out the intercooler, my guess would be the connection from the intercooler to the charge pipe. The factory o-ring that seals the connection on the F30 N55/N20/N26 is pretty fragile so pulling it a few times may have cause it to wear out. Also, the o-ring has a "lip" edge on it that needs to be facing outwards. This lip is pretty thin and prone to ripping. Also when the o-ring starts to wear out, it tends to roll the o-ring inside the flange when connecting so that the "lip" edge goes inwards. Thus, the o-ring does not get a good seal. If the soapy water test shows a leak at this connection, I would recommend changing the o-ring. The BMW part # for the seal is 11618506786. Fred |
09-23-2015, 12:40 AM | #3 |
Rep 2,358
Haha I totally forgot about that o-ring - rookie mistake Good to know there is a bit more boost to gain.
Dyno plans today but that would be a waste - Ill be back
(A Dane in China) |
09-23-2015, 12:45 AM | #4 |
Rep 863
Harkes,
That would explain the loss hehe. Make sure you inspect the o-ring when you put it in. You will see the "lip" I am referring to. Make sure it is still pretty stiff and not ripped. When you put it into the groove in the charge pipe, make sure that "lip" is facing outwards of the groove. Fred |
09-23-2015, 01:13 AM | #5 |
Rep 2,358
Evolution Racewerks
Yes it gotta be that o-ring. I did not remove it from the CP but I also have not inspected it. Highly likely its damaged with all the IC fiddling. Ill replace all three while at it. Is there a "best practice"? E.g. disconnect the rubber elbow and install the IC end of the CP alone first?
(A Dane in China) Last edited by harkes; 09-23-2015 at 01:29 AM.. |
09-23-2015, 02:13 AM | #6 | |
Rep 1,349
Drives: BMW F80 M3
09-23-2015, 04:22 AM | #7 |
Rep 2,358
Is it a good idea to apply some dish soap to the O-rings to aid installation and seal a bit better?
(A Dane in China) |
09-23-2015, 09:16 AM | #8 |
BimmerPost Supporting Vendor
4918
Rep 115,980
They should install and seal without anything, but you can try a very small amount of oil to get them to slip in easier.
Mike |
09-23-2015, 09:18 PM | #9 |
Rep 2,358
Ill give it all a good clean and apply some WD40 before assembly
(A Dane in China) |
09-23-2015, 11:48 PM | #10 | |
Rep 1,349
Drives: BMW F80 M3
09-23-2015, 11:51 PM | #11 |
Rep 2,358
(A Dane in China) |
09-23-2015, 11:52 PM | #12 |
Rep 1,349
Drives: BMW F80 M3
09-28-2015, 03:59 AM | #14 |
Rep 2,358
Replaced both seals for the IC and one of them was actually slightly damaged...but no change. Still ~1.5psi short up top
Next would be to pressurize the system from turbo outlet to throttle body. Can I just do it like so:
(A Dane in China) |
09-28-2015, 08:35 AM | #15 |
Rep 648
Next would be to pressurize the system from turbo outlet to throttle body. Can I just do it like so:[/QUOTE]
Add the soapy water during a dyno run in order to have pressure all the time. Don't pressurize your system by compressed air. It will mess things up. (And use MS4 instead of WD40 ) Krelle
Ist der Motor kalt, Gib ihn sechs ein halb.....
