09-01-2015, 07:52 AM | #1 |
Rep 105
Aftermarket Diverter Valve
Has anyone tried this Diverter valve yet? If so, what're your opinions.
http://www.gfb.com.au/tms-turbo-mana...ve-T9356-27727 |
09-01-2015, 09:31 AM | #2 |
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
All this valve does is allow boost pressure to bleed off back into the intake tract ahead of the turbo when the throttle is closed to prevent the back pressure from causing the compressor to stall and eventually weakening it. It's not going to provide higher boost, but it could open sooner to prevent the aforementioned compressor stall under higher boost levels. Unless you're going to be running very high boost pressures and doing some serious racing, you probably won't need this.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
09-02-2015, 10:06 AM | #3 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
Get it. It made a world of a difference on my car. I couldn't go above 20psi without my factory DV failing and causing my car to fall flat on its face. Now I'm running 27psi no issues at all and it responds way better than the factory DV.
09-02-2015, 03:18 PM | #4 | |
3441
Rep 79,211
We've heard the same from our customers. The GFB DV+ is becoming increasingly popular and many people are noticing they are not leaking boost anymore. |
09-02-2015, 05:25 PM | #5 |
Rep 4,323
Are you losing boost?
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
09-02-2015, 05:43 PM | #6 |
515
Rep 1,063
I was leaking boost before I had put in my pure stage 2, just wasn't anything I could do about it because the DV+ wasn't out yet. And it still wasn't out when I did install my stage 2. I had to install it with the turbo already on and WOOOOOOOOW talk about a royal PITA.
09-07-2015, 03:47 PM | #7 |
Rep 105
Yeah, I have a catless dp, intake and JB4. No matter which map I use I cannot get above 14psi and after psi peaks around 4k it doesn't hold pressure. It falls all the way to redline. Under heavy acceleration I here a sort of double air purge. I checked all pipes and connections and everything looks good. I found this DV while looking for something else to diagnose
09-07-2015, 06:49 PM | #8 | |
BimmerPost Supporting Vendor
4918
Rep 115,980
Mike |
09-07-2015, 08:23 PM | #9 |
Rep 105
Mike, thanks for the reply. I had sent my logs to Steve and Jon a few weeks ago. I can go on and on about the exceptional customer service that they have provided so far. From the logs you can see PWM and FF are maxed out. Steve stated that it looks like a leak. I inspected everything I could visually and the tubes and hoses look good. Does a DV replacement seem like a logical next step?
09-07-2015, 10:37 PM | #10 | |
Rep 4,323
09-08-2015, 02:41 AM | #11 |
Dream crusher
984
Rep 2,421
Are you sure it's the DV and not the engine protecting it self by dumping boost? I thought I had a leaky DV and it turns out the ecu was dumping boost and pulling back power to protect the engine.
IG: @bmwdoubles |
09-08-2015, 10:25 AM | #12 | |
4918
Rep 115,980
Mike |
09-08-2015, 11:17 PM | #13 |
515
Rep 1,063
Do it, lol I'm telling you from experience. I'm not the only one I've seen with a leaky DV on F series N55's, that includes the 1, 2 and 5 series. Even if mine wasn't leaking, I would still get this just due to the fact that it responds so much better than the factory DV. And it's cheap. Just a PITA to install if you don't have the turbo already off of the car.
09-09-2015, 08:36 AM | #14 | |
Rep 851
09-09-2015, 08:49 AM | #15 |
515
Rep 1,063
I didn't take any pictures of the install, and there really isn't much to see, other than the 1"~ spacer that it adds. Everything is internal. The hardest part is getting room to remove the 3 hex screws that hold it in.
What I ended up doing was removing the FMIC, lifting the radiator up (as high as it will go without disconnecting the hoses going to it, which required uncoupling some hoses and unmounting some small radiator attached to the side of it on the drivers side, so I can run my extension with the round tipped hex sockets through the lower grille and get to the hex screws on the DV) unbolting the water pump and bracket holding the water pump and pushing it to the side as best I could without removing hoses, and using some round tipped Hex head sockets to remove the two screws I couldn't reach with traditional hex toolset the DV. The round tips are a necessity because they allow you to use them at an angle, which is your only option. If I had done it this way in the beginning it wouldn't have taken as long, probably half as long lol....so maybe a couple of hours? Just took me forever to figure it out after trying every way possible with ought having to disconnect and remove the water pump. The tiny amount of space you have to work with is what makes it difficult. |
09-09-2015, 09:41 AM | #16 | |
Rep 851
So you saying with my OEM stuff it woudl probably be easier. |
09-09-2015, 09:49 AM | #17 |
515
Rep 1,063
No, exactly the same. Other than it will be more difficult to remove your intercooler if it's factory cuz I don't have to deal with those retarded clips that BMW put on the intake system piping anymore. And I did all my installs myself except for the turbo itself so I already know how everything comes apart. so time wise it might be longer for you, but still the exact same steps as I described above.
09-09-2015, 10:38 AM | #18 | |
Rep 851
09-09-2015, 02:51 PM | #20 |
Rep 851
09-09-2015, 04:53 PM | #21 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
09-09-2015, 05:12 PM | #22 | |
Rep 105
Rocco |
