2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Tracking / Autocrossing First Track Day -- Should I?
      08-28-2015, 05:05 PM   #1
jhbjrpdx
Drives: 228i Sportline
I did several track days with my lightly modified Cooper S. Loved it. Now with the Sportline 228i, I'd like to try to get the confidence I had with the Mini by doing a beginning HPDE. Brakes are stock. Tires are stock run flats. If it is just about learning the car (rear wheel drive) is there an issue taking it out stock? Thx.
      08-28-2015, 07:59 PM   #2
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
I took mine to the Hockenheimring stock without issue. Brakes even held up fine.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
http://www.instagram.com/steve_inf31
      08-28-2015, 08:42 PM   #3
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
Just make sure you are not underinflated or you will be rolling over and killing the shoulders on your tires... specially with the little camber stock car has....eventually you might want to get the M4 LCA
you should probably start 38-40 cold 44-46 hot...
Do 1 session and check the rollover arrow on your tire to make sure you are not rolling over... you can then start lowering the psi till you find what's the best setting checking wear is still above the arrow
2addicts
