F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > BMS intake vacuum hose
Studio RSR
      08-26-2015, 10:52 PM   #1
Lord_Uzi
Drives: F30 335xi M Sport
Today i installed my intake, and the only thing left to do was put in the vacuum pump, and i tried many times and it wouldn't fit at all! any idea on how to fix this?
      08-27-2015, 09:29 AM   #2
Earthmaster
Drives: 15' M4 Austin Yellow
Lol another person having issues with this. I had the same issue when I first installed it. Personally I would just keep going ham on it with the help of another person and make sure you try not to break the plastic around it. I eventually got it 70% in and I gave up, drove it around and it eventually sucked its way into 100% in. Not sure how but it was fine. Every other install and uninstall was 100% easier, its always the first time. maybe use a small portion of oil to butter it up?
      08-27-2015, 10:16 AM   #3
Lord_Uzi
So what if I already broke the plastic around it ? lmao
      08-27-2015, 11:21 AM   #4
Earthmaster
Then it don't matter, Mine was broken already during original install. It doesn't really matter to be honest. Just elbow grease turn and push slowly.
      08-27-2015, 08:19 PM   #5
RedlinePSI
Drives: Something else
Why do these companies have such issues designing the vacuum hose connection properly? The AMS one is located too far away and requires you to "stretch" it. Do they not test fit and see somethings a little off?
      08-28-2015, 07:41 AM   #6
JS23
Drives: E46 M3>E92 335>F32 435>F82 M4
i had the same issue!!!
also, i broke the plastic but it didn't matter.
I found out that after you drove the car a bit and everything is a bit hot, its much easier to install that vacuum hose.
f30post
