..::PSI::.. The Ghost Chameleon
08-01-2015, 02:00 PM | #1 |
2135
Rep 5,011
Legend tells of a warrior that moved in the shadows, striking at will without warning, only to disappear before the enemy caught even a glimpse. While we here at PSI don't always believe in legends, what we do believe in are diehard enthusiasts with a true passion for BMW and motorsport, and the friends we make within that category. Perhaps one of the clearest examples of this single-minded focus is the owner of this unforgettable E92 335is. Originating from South Florida, they came to us with a simple goal: to create one of the most unique and purposeful cars of its kind in the country. It needed to be fast and effective on a race track or road course while maintaining a level of visual appeal. Only the very best solutions were to be used, enabling the user to slip in and exact the maximum amount of damage before fading into the distance. It's truly refreshing to have conversations with individuals who think these kinds of terms. Perhaps you know one. We discussed ideas, laid out plans, and worked late into the night to ensure this project came together correctly. PSI doesn't have a reputation of doing things halfway, so when we commit, it's full speed ahead. Immediately we knew that everything had to begin with the chassis. In motorsport, more time and effort is put into the chassis than virtually anywhere else. Steering, braking and suspension are incredibly crucial to quick lap times - especially the latter two. Power is great to have, but without a way to channel that power to the ground on the track, that energy is often lost or dissipated through loss of traction or excess body movement. Similarly, without reliable stopping ability, unwanted seconds are added with increased braking distances and the inability to turn in properly before hitting the apex. For the perfect ride height while maintaining good compliance, we installed a set of KW Clubsport coilovers that allow for fine-tuning the critical compression and rebound attributes of a suspension setup. In front of those are a complete high-visibility StopTech 355mm/345mm big brake kit with calipers painted in Ithaca Verde for maximum contrast with the body color and wheels. More on that aspect in a moment. These monster units ensure fade-free speed reduction, lap after lap, while the sturdy SPEC Stage 2 clutch and UUC short shifter enable quick, fluid movement between gears. A gorgeous set of Apex EC-7 18" wheels wrapped in Nitto NT05s help reduce weight, look fantastic, and grip like a cat being held over a pool. We wanted maximum chassis stiffening, so a full bolt-in roll bar was sourced from Fall-Line Motorsports, also painted Ithaca Verde, and a snug set of the venerable Recaro Pole Position seats were fastened down, using Macht Schnell floor mounts. For FIA-level restraints, we turned once again to Sabelt, who delivered an amazing 6-point harness to hold the driver in place while engaged in combat. Behind everything, working in concert with the roll bar, is a new PSI Edition alcantara rear seat delete and closeout with custom stamped aluminum panels. While we have not advertised the PSI Edition line much as of yet, a build on this level requires some truly innovative touches, and this one delivers in spades. To guide the assault, a BMW M Performance alcantara steering wheel with Ithaca Verde stripe was installed, and a P3 Cars boost vent gauge monitors vital signs. Power is delivered in short order by a BMS JB4 for N54, BMW DCI, and a healthy pair of VRSF catless downpipes. Our good friends and neighbors at Active Autowerke, who have teamed up with us on a great many projects in the past, supplied a charge pipe and BOV, their excellent front-mount intercooler and a full stainless exhaust system. The careful combination of all these parts ensures a never-ending surge of building acceleration off the line and out of each corner. Last but certainly not least, we addressed the exterior. Again, it was decided to go big or go home, so the entire roof was removed and an OEM E92 M3 carbon fiber roof and headliner replaced it. Needless to say, not only does it look amazing, the functionality of a lower center of gravity serves a significant purpose while cornering. Additionally, OEM E92 M3 side mirrors were painted in Ithaca Verde to match the 335is badges, the BMW Performance carbon fiber rear spoiler’s CRT stripe, and the i8 style front grilles. Completing the aggressive motorsport approach is an Arkym carbon fiber front lower spoiler, adding that extra bit of additional downforce. While the original paint color was black, we had a matte gray wrap applied by Carbon Wraps Orlando, and the effect is mouthwatering when paired up with the black wheels, carbon fiber roof and those unmistakeable Ithaca Verde accent pieces. In the end, we created a machine designed for relentless attack during competition events, and integrated the highest quality parts with ingenuity and creativity. This is not a BMW for the faint-hearted, and while we don't wish to start a mass panic, perhaps while at your next SCCA or HPDE you may wish to check your surroundings more carefully than usual. A ghostly apparition may suddenly appear, and just like that . . . it will be gone. MOD LIST Suspension and Brakes KW Clubsports Stoptech BBK F/R (355mm/345mm) in Ithaca Verde Apex EC-7 18" Nitto NT05s SPEC Stage 2 clutch UUC Short Shift Kit Motorsport Hardware 75mm Studs/ and race nut conversion Interior Fall Line GTR Roll Bar painted Ithaca Verde RECARO pole positions Macht Schnell Floor Mounts and Anti Sub Bar BMW M Performance alcantara steering wheel with Ithaca stripe Sabelt 6-point competition harnesses P3 Cars boost vent gauge PSI EDITION alcantara rear seat delete and closeout with stamped aluminum panels Performance BMS JB4 (N54) BMS DCI VRSF catless downpipes AA charge pipe and BOV AA Sport front mount intercooler AA full stainless exhaust Custom coding by Mike Benvo @ BPM Sport Cosmetic OEM E92 M3 carbon fiber roof & headliner OEM E92 M3 side mrrors painted in Ithaca Verde Matte gray wrap by Carbon Wraps Orlando i8 style painted front kidney grilles Ithaca Verde 335is badges BMW Performance carbon fiber rear spoiler with CRT stripe Arkym carbon fiber front splitter Enjoy the photos! |
08-01-2015, 02:12 PM | #2 |
Ether
59
Rep 163
Drives: 2023 X1 Msport
Dope
08-01-2015, 02:45 PM | #3 |
Rep 1,834
Drives: 08 E90 335xi TiAg
Taillights = yuck.
08-01-2015, 02:47 PM | #4 |
Rep 1,037
Any track videos???
M340i: Arctic White, 790M wheels, Cognac interior, Aluminum Tetragon trim - Totaled
08-01-2015, 03:29 PM | #5 |
Rep 1,665
Wheels, Front kidney grills and those green badges all need to go lol other than that, sick build
2011 335IS Alpine White|Coral Red|DCT|BuraQ E60 Tune|DCI|VRSF 3" DownPipes| ER ChargePipe w/ HKS SSQV BOV|VRSF 7" FMIC|RB PCV| BMS Oil Catch Can|NGK 5992|AQUAMIST HFS-4 w/Twin Methanol Tank|Custom Exhaust| ST Coilovers| and a METAL FOOT
08-01-2015, 03:39 PM | #6 |
Rep 1,665
Where can I get that rear seat delete from? Price? Thank you
08-01-2015, 07:46 PM | #7 |
7409
Rep 10,215
Yeah I think the car would look better without the green highlights on the grills/badges. (or the blacked out tails)
Quality looking building nonetheless. |
08-02-2015, 07:17 PM | #9 |
Bodeine Brazy™
1268
Rep 894
beast mode. lose the blacked out tail lights and add the arkym rear diffuser to match the front.
08-02-2015, 09:00 PM | #10 |
Rep 2,669
Drives: e92 + f15
Would like it if it lost the tinted tails.
08-02-2015, 09:14 PM | #11 |
Rep 951
Please lose the Tails and all of the exterior Green Highlights.
Otherwise this is a top notch build!
08-03-2015, 03:40 AM | #12 |
///Project Aura
390
Rep 889
I agree with the removal of the smoked out tails.
Some of the green highlighting is overdone, but I definitely like the rear end 335is badge in green--I feel that it adds nice contrast to the rear. The sides ones and mirror caps would look better blacked out imo. The front grills, can go either way. I like them and then I don't. Neutral for me, but definitely not ugly. |
08-03-2015, 08:16 AM | #13 |
Custom User Title
412
Rep 1,337
God, I love that rear seat delete. So proper. Great work!
08-03-2015, 09:42 AM | #15 | |
Rep 1,369
Drives: F80 M3 6MT
Beautiful ride, the rear seat delete is the cleanest I have ever seen. I personally love all the Ithaca Verde highlights
15 F80 M3 Mineral Grey/Black 6MT
08-03-2015, 12:27 PM | #18 |
Rep 1,184
i like the green touches... without them, the car will look kinda boring... i don't like the tails though, sorry!
dope build nonetheless
PAST: 2007 E93 335i 6MT NOW: 2012 F10 M5 Facebook: Achu Ckr|Twitter: AchuCkr|Instagram: AchuCKR|Flickr: AchuCKR|G+: achu.ckr THE BUILD THREAD|COMPILATION OF PHOTOS |
08-03-2015, 02:15 PM | #20 |
Average Car Exceeding Expectations (ACEE)
358
Rep 4,806
I would say thanks for being different. I love the lime green accents. I would def say the rear diffuser should be a little more aggressive looking for what all you have done. Pin stripe the bottom of the front lip lime green would be cool also. And last but not least if you could have gotten the M3 style fenders and put the lime green 335IS logo on the side marker.
too much to list...just know its wide and bagged |
08-03-2015, 03:44 PM | #21 |
Member.
201
Rep 827
Don't care for the green highlights throughout the exterior, but definitely a quality build.
08-03-2015, 04:36 PM | #22 |
Specialist
1310
Rep 2,707
I think the 335iS badging in green is a little much. Rear diffuser should have been carbon or gloss black. But maybe all of it is a wash if you just left red tails with a just slight tint or even better with the Republic Wraps style that highlights the tubes of the LCI bars. This is a hell of a build. The interior is just WOW.
Tags |
335is, bmw, motorsport, precision sport, psi |
