08-05-2015, 03:50 PM | #6 |
Rep 100
Is there any complete breakdown of each map setting out there? I have JB4 but have only run maps 1 and 2 out of fear of not having the right set up for the rest of the maps.
2014 Mineral Grey 335xi ZMM, ZPP, ZCW, ZDA, ZTP.
Performance: FBO; MPE, Brembo M BBK, ER CP, ER DP, Phoenix IC, JB4, KW V2, Mechunik Front Tower Strut Brace, Michelin PS AS3+, JL Audio W6 10" HO sealed/ported box, and a bunch of other stuff you probably don't care about either. |
08-05-2015, 05:04 PM | #7 |
Rep 939
08-06-2015, 05:37 PM | #8 | |
BimmerPost Supporting Vendor
4918
Rep 115,980
Map 0: JB4 disabled Map 1: Peak boost 12.5psi, suggest for most racing applications. Map 2: Peak boost 14.0psi, suggested for those using exhaust mods and 93 RM2 octane or higher fuels Map 3: Progressive methanol mapping Map 4: Stock performance, JB4 on Map 5: Autotuning, enabled in 8.8 and later firmware Map 6: User definable map. Suggested for troubleshooting by professionals only. Map 7: Race gas map. Peak boost 18.5psi. Requires straight unleaded race gas. E85 Use Models equipped with the pneumatic wastegate & flex fuel connector may experiment with up to 40% E85 mixtures. Some cars tolerate E85 and some do not. Cars that do not tolerate the mix will "buck" or "miss" at full throttle. In some cases map 7 can be used on the E85 mix and in other cases map 2 is the highest that can be used. It's best to start slowly and work your way up in terms of aggressiveness when experimenting with E85 mixtures. |
08-06-2015, 05:46 PM | #9 | |
BMW Fanatic
331
Rep 1,076
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
08-06-2015, 09:01 PM | #10 | |
Rep 100
08-07-2015, 04:40 PM | #11 | |
4918
Rep 115,980
Mike |
