Change track using steering buttons from iPhone
07-31-2015, 07:32 PM | #1 |
Rep 36
Hi all,
I have a 2007 e92 with CCC, it gets annoying having to change my tracks using my iPhone rather than the iDrive system itself. I use the aux cable, but don't have a usb cable otherwise would have used the Y cable. Is there an inexpensive way to be able to control the music using the controls in the car? Thanks! |
08-01-2015, 02:22 AM | #2 | |
267
Rep 2,741
08-01-2015, 07:41 PM | #3 |
Rep 36
This is a smart watch? I was after something where I can press the track changing buttons on the steering wheels left and right unless the watch can be programmed to work with the car??
08-01-2015, 09:09 PM | #4 |
Rep 13,134
You need USB to do what you want to do
And then you might as well put your tunes on a USB flash stick. See Makkan00 for an upgrade. http://www.e90post.com/forums/showthread.php?t=704363 |
08-01-2015, 11:20 PM | #6 |
Rep 13,134
A usb cable won't help without the usb module.
There is no USB on some cars its and option. On the older setups you need a mulf 2 hi module on some of the newer pro radios its built in not sure about idrives. |
