07-20-2015, 04:48 PM | #1 |
BimmerPost Supporting Vendor
4925
Rep 116,006
ER F30 N55 Charge Pipe Install - Install Guide and Suggestions!
I was asked to start a new thread for the ER F30 Charge Pipe. I am attaching the official install guide, and anybody who wishes to post any tips or tricks or advice please feel free...
Mike |
07-20-2015, 08:31 PM | #3 |
4925
Rep 116,006
I have not heard of any and we've probably sold 1000+ units over the N54/N55 platform.
Only time a code pops up with an FMIC or CP install is if the couplers are not tightened down, usually with FMICs on the cold side and it just pops off triggering a boost under code. Beyond that nothing I have seen. Mike |
07-21-2015, 11:48 AM | #4 |
24406
Rep 191,282
If installed correctly, it will not trigger any lights. Are you getting any codes after installation of the CP and / or FMIC?
07-23-2015, 08:25 AM | #5 |
Rep 4,323
Have both, and neither have triggered anything.
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
07-24-2015, 02:34 AM | #6 |
Rep 243
If you don't tighten the clamps enough it can through some boost leak codes.
JB4 Stage 2 | aFe Magnum FORCE Intake System DRY | ER Chargepipe | ER CATLESS Downpipe | ATM Intercooler | BMS 2.3 Gal Meth Inj kit | Bilstein B14 | OEM Slotted/Dimpeled front rotors | Cool Carbon brakes | Go Fast Bit DV+ | Pure Stage 2 Turbo | Pure inlet
07-24-2015, 10:07 AM | #7 |
Rep 34
The biggest painin the ass will be disconnecting the factory charge pipe from the intercooler. What I did was take a tiny scredriver and pop it under the connection then with both hands push and wiggle the tabs towards the front of the car. Once its off. I would pull the charge pripe through the the tiny hole. its not hard once youve done it once.
PS no beed to disconnect the other side of the intercooler. |
07-24-2015, 11:46 AM | #8 | |
4925
Rep 116,006
Mike |
07-26-2015, 03:51 PM | #10 |
4925
Rep 116,006
04-30-2016, 06:39 AM | #11 |
Rep 261
05-19-2016, 12:21 PM | #12 |
Rep 1,723
Hey Mike - with just a Jb4 no other mods on 93 octane is a CP needed, or only if you are going downpipes, tracking the car, E85 etc
05-19-2016, 12:31 PM | #13 |
24406
Rep 191,282
It is always recommended to upgrade the CP when tuning the car but from my experience with our customers it is only mandatory if you are running map 2 or higher boost
05-19-2016, 06:25 PM | #14 | |
4925
Rep 116,006
I would never call it a MANDATORY upgrade but one that is highly recommended. Mike |
05-22-2016, 11:25 PM | #15 |
Rep 324
quick question, In what direction must the MAP sensor on the ER chargepipe be installed, does it matter? facing down like stock?
thanks!
2018 BMW M3 ZCP- Imola Red
Follow me on Instagram: @hsdvisuals |
05-23-2016, 01:58 AM | #16 |
Rep 1,125
05-23-2016, 02:00 AM | #17 |
Rep 1,125
For the ix models, I found it easier to pull the original charge pipe from the top. You'll have to remove the black plastic cover on the driver side (one screw). Took me 5 minutes from the top vs 20min thru the bottom.
05-23-2016, 08:02 AM | #18 |
Rep 324
So make it faced down like stock? Sorry I totally forgot about that small detail during install lol
05-23-2016, 09:49 AM | #19 |
Rep 1,125
05-23-2016, 11:01 AM | #20 |
Rep 324
Ok thanks!
05-24-2016, 12:31 PM | #21 |
Rep 4,323
Reuse your O-rings and gaskets!
