07-14-2015, 11:40 PM | #1 |
///M
159
Rep 432
Drives: 2012 e92 335i m sport BSM
Need some info please CEL with bms intake and MPE
I installed the bms intake on my 2014 f30 335i and I had no cel 2 weeks later I install the MPE. No cel. A couple of days pass now my cel is on any info what's causing it. Also do any of these mods void my warranty? I also want to install a ER downpipe. Thanks in advance.
'14 335i sportline
?18 m3 comp YMB ?21 m5 comp BHG Ig handle willybeamin305 |
07-15-2015, 07:16 AM | #3 |
Rep 376
had the same problem with the injen intake. fine for almost 2 weeks then cel came on, car drove fine but after a while it got to me so went back to stock and took it in. bad maf sensor, replaced under warranty.
07-15-2015, 10:46 AM | #4 |
BimmerPost Supporting Vendor
24201
Rep 190,807
+1 on reading the codes
07-15-2015, 11:24 AM | #5 |
///M
159
Rep 432
Code is P00BD
'14 335i sportline
07-15-2015, 01:57 PM | #6 |
Rep 4,323
Were you PPK?
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
07-15-2015, 10:39 PM | #7 | |
///M
159
Rep 432
'14 335i sportline
07-16-2015, 12:22 AM | #8 | |
Rep 1,503
Hope there will be a better solution though.
FBO M235i r
F80 M3 |
07-16-2015, 04:48 AM | #9 |
Rep 75
Your intake is the issue. Switch back to stock and clear the code and it won't come back. I had the same issue with 2 different aftermarket intakes
07-16-2015, 06:19 AM | #10 |
Rep 144
I had same problem with my Injen as well. Would always get a CEL, always got same code 102A01. 3 times I took my car to dealer and they always replaces maf sensor. I never installed the intake again after the 3rd time. To much of a hassle. I was never able to find out why it would kill the Maf sensor either. Strange.
07-16-2015, 02:48 PM | #11 |
///M
159
Rep 432
Well I just cleared the code and it hasn't came back on. But I'm expecting it to come back one day. I guess I'll just keep clearing the code. Will clearing the code bring me problems in the future?
'14 335i sportline
07-17-2015, 07:58 AM | #12 | |
4918
Rep 115,980
Mike |
07-17-2015, 10:31 AM | #13 |
Rep 34
Yah I have the BMS intake installed and the car at low rpms seems to hiccup when crusing with a light throttle. Everyone is telling me to change the intake back to stock and it will go away. I will be doing that tonight. I was running map 5 and 2 and switched to map 0 to see if it was the jb4 and wasent so I am almost sure its the intake. I iwsh they had a fix for it as I love the intake but i hate the hiccup its causing.
07-17-2015, 10:35 AM | #14 | |
///M
159
Rep 432
'14 335i sportline
07-18-2015, 01:30 PM | #15 |
Rep 34
I disconnected my MAF and boom the car is running like a dream. It may trigger the check engine light for a few seconds then it goes away. I have no more bogging or rough idles or anything. I will keep u posted to it seems to be the fix
07-18-2015, 01:41 PM | #16 | |
///M
159
Rep 432
'14 335i sportline
07-18-2015, 04:27 PM | #17 | |
4918
Rep 115,980
Mike |
07-18-2015, 09:25 PM | #18 | ||
///M
159
Rep 432
'14 335i sportline
07-20-2015, 01:24 AM | #19 |
Rep 243
Do you have JB4?
JB4 Stage 2 | aFe Magnum FORCE Intake System DRY | ER Chargepipe | ER CATLESS Downpipe | ATM Intercooler | BMS 2.3 Gal Meth Inj kit | Bilstein B14 | OEM Slotted/Dimpeled front rotors | Cool Carbon brakes | Go Fast Bit DV+ | Pure Stage 2 Turbo | Pure inlet
07-20-2015, 08:28 AM | #20 |
4918
Rep 115,980
07-20-2015, 10:35 AM | #21 |
///M
159
Rep 432
Ok so I'm forced to get the jb4 or take off the intake....
'14 335i sportline
