07-13-2015, 12:47 AM | #1 |
Rep 224
SPARK PLUGS for 435 ECU TUNED
Hi everyone,
I 've just up my 2014 435 F33 with ECU tuning and pure stage 1 with Turbo to intercooler TIC ready to be installed. Oem spark plugs has missfire, burning time too short and prone for breaking. Which one you suggest guys? S55 spark plugs or Ngk 95770 both gapped? Thanks 4 yours help... |
07-13-2015, 05:21 AM | #2 | |
Rep 648
Ist der Motor kalt, Gib ihn sechs ein halb.....
07-13-2015, 05:45 AM | #3 | |
Rep 1,349
Drives: BMW F80 M3
07-13-2015, 07:41 AM | #4 | |
Rep 224
Did you gapped ? 0,25 or 0,22? Some other report that M4 spark plugs works fine even above 25psi. |
07-13-2015, 10:31 AM | #5 | |
Rep 648
I haven't tried the ones from M4. The original 335 plugs can be used as well. The other are better though. Using other plugs doesn't give you steadier idle nor gain any power, it's pure engine protection. /Krelle
07-13-2015, 10:39 AM | #6 |
BimmerPost Supporting Vendor
24199
Rep 190,807
How old are your spark plugs?
07-13-2015, 11:57 AM | #7 |
Rep 224
07-13-2015, 12:01 PM | #8 |
24199
Rep 190,807
Im assuming you have no datalog feature with your current tune.
07-13-2015, 02:02 PM | #9 |
Rep 467
Will a higher flowing LPFP help with the HPFP problem? Sometimes it is the LPFP that can't maintain a consistent pressure so the ECU freaks out and throws codes.
07-13-2015, 07:54 PM | #10 |
Rep 159
I have f30 335i with ecu tune. It had misfires, I changed oem spark plugs to M-series spark plugs (m4, m5/m6 the same partnumber) but the issue came again. Then I flashed my car with another tuning file and now I have no any problems. No misfires! So the problem is exactly in flash tuning quality.
07-13-2015, 11:31 PM | #11 | |
Rep 1,349
Drives: BMW F80 M3
07-13-2015, 11:32 PM | #12 |
Rep 1,349
Drives: BMW F80 M3
Yup its your air fuel mixture. When tuner flash your car he needs to leave the air fuel mixture stock. Then no issue!
07-14-2015, 09:56 AM | #13 | |
3441
Rep 79,211
07-14-2015, 11:00 AM | #14 | |
24199
Rep 190,807
Just because you had no misfire on the second tune does not mean the second one is higher quality, it might just be more conservative. Your first tune might have been too aggressive for your mods.
07-15-2015, 10:27 AM | #15 | |
Rep 4,323
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
07-15-2015, 02:06 PM | #16 |
Rep 1,349
Drives: BMW F80 M3
Without a log it is all hard to say. I can just speak for myself and all the missfires I have had so far is due to the HPFP not being able to follow. Either too rich tune, too much ethanol etc etc... All resulting in logs showing HPFP dropping under 10 and voila missfire appears. No hardware issue at all.
