2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum Regional Forums USA - California ACM | Coding Special $80
      07-02-2015, 06:32 PM   #1
Sal@AUTOcouture
Sal@AUTOcouture's Avatar
732
Drives: M760xi
All coding in house at our shop located in Van Nuys
Section 1 Coding Options: Activating/disabling of features
Section 2 Retrofit Coding: Adding/Removing/Disabling Hardware (Such as alarm)
Section 3 Software Flashes: Updating modules in the vehicle (update to current software, or performance software)
Please Read:
*Coding is customized to your taste, please select options that relate to your life style, needs/ wants
*All coding done is warranty & dealer friendly. No software is added or removed from the vehicle.
*If you do not see a coding option that you like to have, please ask.
*If you have aftermarket lighting, please notify before your session.
F2X/F3X/F8X Coding Options
Comfort/Lighting Options:
 Euro MDM
 Disable Seat Belt Chimes (Passenger, Driver, or both)
 Disable Seat Belt Warning
 Windows up/down & closing/opening of sunroof with key
 Windows up & closing of sunroof with Comfort Access (Comfort Access required)
 Folding Mirrors with key
 Folding Mirrors with Comfort Access (Comfort Access required)
 Unlock doors when engine is turned off
 Window safety feature (When window is rolling up, you can open the door without it stopping, one touch operation of windows with door open)
 Welcome Lights Fog Lights (When you hit unlock, your fog lights come on)
 Removal of Amber Headlight Sidemarkers (Euro Look, will only come on when you signal) (Excludes LED Headlamps)
 Fog Lamps with High Beams (Fog lights will not shut off when high beams are activated)
 Turn Off Daytime Running Lights
 Digital Speed Display (Speed will be displayed in numbers center of the cluster, added option does not remove anything, M3 style)
 Adjust Low Fuel Warning (Standard 1/8 can be moved to 1/4)
 Flashing Brake Lights (Brake Force Display) (Upon hard braking the brake lights will flash)
 Increase Triple Blinker Blinks (Increase from 3 blinks to as high as 7)
 Door handle LED on in reverse
 Increase Ambient Lighting (standard 60%)
 Auto Start/Stop feature default to off or memory
 Sports Display (Display HP and TQ gauges, limited to select vehicles)
 Enable Sports+ Mode (please verify you DO NOT have this before adding it to your list)
 Close tailgate with key and inside cabin button (For GT models only)
iDrive/Navigation Options:
 Enable DVDinMotion (Watch DVDs at any speed for cars with navigation)
 Removal of iDrive Disclaimer Message (no more pushing accept when first starting the car)
 Add Fuel Stop Proposals (standard on 2011+ cars) (For 2009+ cars only)
 Enable Weather band (limited to some vehicles)
 8 Shortcut buttons (standard US vehicles have 6 shortcut buttons, you can make your AM/FM and mode button to shortcut 7 & 8 but you lose your AM/FM & mode button function)
 Inband Ringtone (transfers the ringtone from your phone)
 M Start up screen (Standard on M3/4, only works on cars with NBT units)
 Video through USB (cars with NBT only, will not work on CIC)
 Enhanced Bluetooth/USB (6NS enable streaming Audio through your phone, and video through USB, video only NBT)
 Digital Tire Display (Display temp and PSI of tires)
F2X/F3X/F8X Retrofit Coding *
All hardware must be installed/removed before coding
 Bulb warning removal (after market HID/LED installs, you must know which bulbs are giving an error, cannot turn off all bulb check warnings, not safe)
 Race Seat Coding (Removal of Airbag/MRS/SRS errors) *Will only code airbags that are fully removed, everything else will stay active
 Roll cage coding (Removal of Airbag/MRS/SRS errors) *Will only code airbags that are fully removed, everything else will stay active
 Alarm Coding (Activation of factory alarm)
 Removal of EDC (Electronic Damping Control) (EDC module must be disconnected)
 Removal of TPMS (Tire Pressure Monitor) (TPMS module must be disconnected)
 CIC Retrofit/NBT Retrofit
 Rear fog light retrofit (Requires euro light switch, or modification of US light switch)
 E-MAIL for any other retrofits or removal of hardware
 Activation of Sirius Satellite Radio (Includes 1 year free of Sirius 2010+ Cars with iDrive)
 Activation of BMW Apps (requires Combox, please email last 7 of vin to check)
 Navigation Map Updates
F2X/F3X/F8X Software Flashes Email for pricing
 Engine Management software update (enjoy the most update to date software for your vehicles engine DME) *Not available to remote coding customers
 Update any module in your car
 Transmission update (update the software for your transmission, helps with shifting, improves gas mileage)
Contact through PM or give a call
(818)-849-6282
Come see us at
14212 Oxnard St
Van Nuys, CA 91401
2addicts
