06-04-2015, 07:39 AM | #1 |
Rep 7,887
Anybody using the M Track Day App?
I used it for the 1st time on Tuesday and found a few issues.On the track map the position of the car puts me on the other side of the curbing or turtles(honest I was on the track)and the G loadings are much lower than I have seen using Harry's Lap Timer.
06-04-2015, 07:47 AM | #2 |
Rep 20,741
Drives: 2021 911 turbo
Same here. The car position relative to the track is not very precise. I wonder if the imprecision comes from innacurate positioning of the google maps rather the car's GPS coordinates themeselves.
The laptimer is likely not as precise as a good quality real data aquisition system, but for the money (free ) and convenience, I find it plenty sufficient for my use.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
06-04-2015, 07:51 AM | #4 |
Rep 7,887
Yep it easy to use and there is quite a bit of useful info if you go digging.I really needed to know that I get 2.3 mpg at full throttle in the lower gears!lol
06-04-2015, 08:44 AM | #6 |
Rep 984
I've had Harry's Lap-Timer since I think 2011 now, always been a great app and has come a long way's. Haven't tried M Track Day but don't see the need to do so.
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
06-06-2015, 10:38 AM | #8 |
Rep 124
This is due to the low 1hz refresh rate of the GPS. This means it pulls a position 1 time every second. If you are traveling at 100 mph then in the time it takes to pull another position you have traveled 146 feet! So the margin of error is huge. 10hz (10 updates per second) is accurate to within one tenth of a second. I have compared 10hz gps times to transponder times and was impressed with how accurate 10hz gps timing can be!
If you are looking for low budget then get Harry's Lap Timer app with an external 10hz GPS. I have Harry's for Android with a Qstarz 10hz GPS. If you want something a little higher end you can check out solutions from Racelogic, AIM, etc.. I also have an older Performancebox which has a built in 10hz GPS. It is showing its age since everything is now an APP on your phone, but it is a standalone unit with great software to break down sessions. http://www.vboxmotorsport.com/index....performancebox Last edited by M3NetNerd; 06-06-2015 at 10:52 AM.. |
06-09-2015, 08:05 PM | #9 | |
Rep 6,218
Before I bought my Solo DL, I had to stay on iOS because it was only on there. Now I have full datalogging so I ditched the iphone finally. |
06-13-2015, 11:04 AM | #10 | |
Rep 1,997
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
06-23-2015, 07:37 PM | #11 |
Sakhir Smurf
314
Rep 594
Drives: Plaid, F82 M4, E46 M3, Sequoia
I'd never had data acquisition before, so I loved using the app! Though, given that it's a street car w/o track safety (roll cage, harness, etc...) I'm actually questioning how much I should be trying to max out the performance of the car.
Perhaps this will be my first foray into getting my F82 track set up the way I have my E46... damn.
2015 M4: Sakhir on Sakhir | M-DCT | Adaptive Suspension | Lighting | Executive | Cameras | HK Sound | Full Leather
2004 M3: Laguna Seca Blue | SMGII | Basic track mods: 18" Square setup on R888s / Performance Friction rotors / SS Lines / Ground Control Street/Track Kit / DTC-60 Pads NASA NorCal Instructor |
