06-03-2015, 12:13 AM | #1 |
Rep 383
Drives: F13 M6 | E92 M3 | '15 Mustang
JB4 M2 on E30 vs GSR Technik Stage 2 on 91 and Stacked Comparo
We did some interested testing today on the dyno with our most recent N55 F30 customer.
First we did JB4 Map 2 running on E30 ethanol mix vs GSR Technik Stage 2 running on 91 octane. You can see the benefit of the higher octane, cooler burning fuel on the top end. Then we compared JB4 Map 2 running on E30 ethanol mix running stock ECU tune against JB4 Map 2 running on E30 ethanol mix running on top of GSR Technik Stage 2 ECU tune. Last edited by GSR Technik; 06-03-2015 at 12:23 AM.. |
06-03-2015, 05:55 AM | #2 |
Pace Car Driver
1548
Rep 3,164
Thanks, but ...
You used E30 because SO many people are running that? Then you used a stack, again because SO many people are doing that too? Why not JB4 Map 2 vs GSR? Like for like? The E30 and the stack just muddies the water. At least for my purposes. |
06-03-2015, 11:55 AM | #4 | |
Rep 383
JB4 Map 2 on E30 should perform better than JB4 Map 2 on 91, assuming the fueling is right so that at least it gives you an some idea of comparison. |
06-09-2015, 12:03 PM | #5 | |
Rep 3,406
But yes, E30 is the sweet spot for these cars. |
06-09-2015, 05:44 PM | #6 |
Rep 2,358
Whats the maximum E-mix a stock N55 can handle in general? E30?
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
06-09-2015, 06:56 PM | #7 |
Rep 3,406
It's not a matter of how much the N55 can "handle." Ethanol is less efficient than gasoline. At increased power levels, these notoriously shitty fuel systems cars simply can't keep up.
With a proper fuel system and tuning, you can run pure E85. |
06-10-2015, 02:07 PM | #8 | |
3441
Rep 79,211
To answer his question, E30 and run some logs to see how things look. |
06-10-2015, 02:46 PM | #9 |
Rep 1,349
Drives: BMW F80 M3
I ran E35 on my pure stage1 N55 together with meth.
Now i am running E20 with meth on pure stage2 turbo. Around 22-23 psi 5-5.5k rpm my hpfp is maxed. Allready got fuel-it stage2 lpfp. Awaiting the tbi kit to see if i can up the E to E40 or more and run more boost. |
06-10-2015, 06:06 PM | #10 | |
Rep 383
