F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > F31 xDrive N47 oil change
Studio RSR
      06-01-2015, 03:13 PM   #1
Bimmer7
Drives: F31
in the past all of my BMWs have had a door in the bottom engine cover which is used to access the oil drain plug. There is no door on my car just two openings in the under panel. It appears the the front opening is to provide access to the front differential and the smaller rear opening is to provide access to the drain plug which has a 17mm head. Could someone confirm that this is the oil drain plug?
Thanks, Darryl
      06-01-2015, 06:31 PM   #2
catskillclimber
Drives: 328d
that is how our F30 328D is laid out, including the 17mm socket to remove the oil drain plug.
      06-02-2015, 02:02 PM   #3
tjlees
England
349
Drives: F30 Chav Mobile
Thanks, Darryl
Don't do the other one (front) it's definitely the transmission.
Remember to torque up to 25nm
      06-03-2015, 03:52 AM   #4
DTP1980
DTP1980's Avatar
Drives: M5 F10 LCI Monte Carlo Blue
An intelligent question. To the layman it would be easy to make the mistake of releasing the wrong plug.
      06-03-2015, 07:17 AM   #5
catskillclimber
Drives: 328d
The front plug is as the OP stated the front differential. The transmission drain is toward the rear behind the engine oil drain.
      06-05-2015, 03:52 PM   #6
Bimmer7
Drives: F31
Thanks to everyone that responded. Oil change done successfully!
By the way, I got the BMW LL-04 oil from my dealer for $8.00/liter, they also gave me a substantial discount on the filter as a BMW CCA member.
Darryl
      06-06-2015, 12:08 PM   #7
tjlees
England
349
Darryl
in blighty, the cheapest branded oil is £8 per litre and £21 for the filter.
f30post
