05-20-2015, 05:10 PM | #1 |
BimmerPost Supporting Vendor
4918
Rep 115,980
Upcoming F Series Wheel Controls & Boost Gauge
BMS has been slowly working on bringing our F series JB4 up to the level of the E series with in dash map switching and some in dash gauges.
To install you drop the panel under the steering wheel by removing 2x 10mm bolts, push the OBDII cable through an existing hole to the firewall to the engine bay, remove the CANbus POSITAPs previously installed, connect the green and brown CANbus wires to this OBDII cable using the supplied wire nuts, and load the dedicated OBDII CAN JB4 firmware. The required custom made OBDII CANbus cable will be about $15 + shipping and we expect to have them in stock later this week or early next week. Current in dash settings as of v1 firmware: '*************************************** 'OBDII In Dash Menu '*************************************** '0 map menu, map shown on tach '1 Active Sound MUTE (not relevant for most N55 models) '2 Boost gauge on fuel, scaling in dash is 0 to boost safety setting, turns on when gas pedal is pressed 50% or more and turns itself off when you resume low throttle use. '3 LED MAX brightness mode. For those with factory LED headlights this option brightens HALO during nighttime operation. '4 OBDII Diagnostic Code Delete '5 1st gear boost limiter '6 2nd gear boost limiter '7 3rd gear boost limiter |
05-20-2015, 05:56 PM | #2 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
What if i already have the halos coded to max brightness already? Will this negatively affect anything?
05-20-2015, 06:07 PM | #3 |
Rep 1,436
I haven't seen this on N54tech yet !
I am a bit confused about positap you mean connect them to the relay of transmission directly and remove the original (green,brown) wires installed ?! if so how the then it's gonna connect to JB4 ?!
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
05-20-2015, 06:31 PM | #5 |
Rep 1,436
05-20-2015, 08:30 PM | #6 |
4918
Rep 115,980
05-21-2015, 12:04 AM | #7 |
515
Rep 1,063
so, this cable allows us to use the options listed above? whats diff from the can connection under the hood, to the one on the OBD?
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
05-21-2015, 01:07 PM | #8 |
4918
Rep 115,980
05-21-2015, 04:14 PM | #9 |
Rep 851
update when there are full instructions and pictures, I don't touch this stuff until ive read thorough instructions like 10x. Not wanting to fawk shit up on my 60k car.
