EXXEL Distributions
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      05-02-2015, 05:46 PM   #1
evanescent03
evanescent03's Avatar
1032
Drives: '24 M3 CS; '22 GT4
Caliper nipple leaking ...
I didn't torque my caliper bleed nipples down because i didn't know the spec and didn't want to OVER a tighten them and damage the calipers...
after my second session I saw a little drizzle of brake fluid coming from said bleed valves (around the threads). ^%*!? .. so not only did it damage the paint on the calipers slightly but now I notice a little sponginess in the brakes. when I get on them, they brake great ... but it's a little squishy and inconsistent. that is probably partially my fault because I'm inconsistent myself but I do think that as there was enough space for fluid to come out, I bet I got some air back into the system.
am i screwed? it doesn't seem BAD, I tightened the valves quite a bit more and the car did fine in the next few sessions but ... has anyone had this happen? got a fix ? I'm going to bleed the brakes a little and see where that gets me tomorrow ...
any input appreciated
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
      05-02-2015, 06:39 PM   #2
FTS
Enjoying driving
FTS's Avatar
Drives: 645
It is not a big deal, you just tighten them. However, if you strip them, then you will need to replace the bleeders, that is not a big deal either. Mine leak too when I get them really hot, but only very little. The important thing is not to strip them, not notice it and go to the track. So, make sure you know how much to tighten them
      05-02-2015, 09:58 PM   #3
evanescent03
1032
thank you! had some great sessions today, looking forward to some more tomorrow! bled the brakes a bit too as I'm not really sure why I started getting the softer pedal feel. car stopped when i asked it to which is the important part.
      05-03-2015, 08:32 AM   #4
FTS
Enjoying driving
FTS's Avatar
Drives: 645
Best of luck and much fun time to you, can't wait to read your feedback.
      05-03-2015, 08:44 AM   #5
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
Once seated, add 1/8 to 1/4 of a turn. If they leaked, you might want to re-bleed the brakes as air as gotten in. No torque wrench needed, but it's around 55 inch-lb of torque. "inch" not "foot"
Daily: G12 750 MSPORT Weekend Car: E90 M3
      05-04-2015, 02:24 PM   #6
MasterC17
Drives: 2015 BMW M3
Mine did the same thing, no big deal, tighten it up. I also have four Oxford Green calipers now hehehe
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
      05-05-2015, 08:13 AM   #7
evanescent03
1032
tightened everything down, bled the brakes after the last session and went back at it the next day. i don't know if i was just less confident at that point or what, but the pedal seemed to have a lot of travel. just once i hit the brakes and i felt a hard-stop of the pedal but poor stopping, not sure what that was about? i let off and applied again and it was fine. all along it seemed like the pedal travel was a little long but seemed to resist fade very well overall.
thanks guys.
      05-05-2015, 09:17 AM   #8
FTS
Enjoying driving
FTS's Avatar
Drives: 645
I think you are describing the infamous "ice pedal" phenomenon.
One version of this phenomenon: http://rennlist.com/forums/997-gt2-g...on-street.html
      05-05-2015, 11:00 AM   #9
evanescent03
1032
wow - that sounds like the ol' ice pedal.. i've never experienced this or read about it before. thank you!!
f80post
