LCI with combox: 6NR, a2dp etc
05-02-2015, 07:32 AM | #1 | |
Rep 275
hey guys...i'm a little confused as to what i can achieve with the car i'm picking up on monday. it's a 10 plate LCI e92, march 2010 build by the information i can find. It has the following options:
What about 6FL? I believe I need this to be able to update the combox? What else does 6FL offer and how hard is it to fit to a combox car? I only ever use spotify, never usb sticks or the stock music players on my iphone 5S or galaxy s6. Also, am I correct in thinking that because it has a combox bluetooth a2dp will work? Can the bluetooth in these cope with having 2 phones sync'd at the same time so if either ring i can answer etc? Thanks, Tom.
Previous: 2002 E46 330i M-Sport (m54b30 LCI), 2007 E92 335D M-Sport Coupe (m57), 2003 z4 3.0i (m54b30), 2010 E92 325D M-Sport Coupe (n57 LCI), 2019 F36 430i M-Sport Pro Gran Coupe, 2018 F36 440i M-Sport Pro Gran Coupe MPPSK
Current: MY2021 M550i, Aventurin Red, Ivory Nappa, Comfort Pack, Tech+ |
05-06-2015, 02:04 PM | #2 |
Rep 275
Anyone? Or is in the wrong forum?
I want to upgrade the maps etc to latest but know that it might have to be done a certain order or might miss out on being able to enable 6NR?
05-06-2015, 03:45 PM | #3 |
Rep 2,770
You should contact Patryk at Bimmer-tech: http://www.bimmer-tech.net/
Your car is too old to have the combox installed from the factory so you will likely need to retrofit it. Patryk can tell you what all is needed and how much. Be prepared for a little sticker shock though.
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
05-06-2015, 03:50 PM | #4 | |
Rep 275
Thanks, will try and get hold of him. For reference, my car isn't too old for combox, it was made the month that they started fitting them and was installed with combox from the factory as per the vehicle order I pasted in the op....this is under my boot carpet: Bluetooth streaming etc is all working. I am only asking for bmw apps and potentially retrofitting 6fl |
05-06-2015, 04:11 PM | #5 |
Rep 2,770
Combox was only available on cars built starting in March of 2011. I know this because mine is one of the first ones to have it. What you see in the photo there is likely the TCU, not the combox.
Edit, perhaps things were different in Europe though. In the US only 3/11 and newer cars came with it.
05-06-2015, 04:25 PM | #6 | |
Rep 275
05-06-2015, 06:28 PM | #7 |
Rep 2,770
In any case, Patryk will be able to sort you out. Just send him the last 7 digits of your VIN and what you want and he will tell you exactly what you need.
