Car shuts off while driving...
03-11-2015, 11:40 AM | #1 |
Rep 142
Drives: 2024 X5 M60i (Marina/Black)
Hi guys, looking for feedback. I have a 2011 335xi coupe (auto).
Monday evening....I turned on my car and it would shut off when I shifted from Park "P" to Drive "D". After this happened about 2 to 3 times, it worked fine. I drove about 20 miles. No problem. Fast forward to Tuesday afternoon....my car would cut off while driving. I would simply be driving and it would cut off as in go completely "limp". My speeds ranged from 10-40 MPH. This happened about 5/6 times (all on local roads) then stopped. I drove about 5 miles. No problem. The steering wheel also tightens when the "shut off" occurrs; brakes still work. Any ideas of what this could be? Seems dangerous as the "shut off" can happen at any time so have not driven it. Will look to take to dealer or indy shop but any feedback would be appreciated it. |
03-11-2015, 07:02 PM | #4 |
Rep 2,120
Check your battery. Mine did that when the battery was below 30% . My lights would dim and shut off too. Does your traction control and brake light symbol come on?
BMW CCA # 473001
03-12-2015, 09:20 AM | #5 |
210
Rep 1,161
First, get the codes read by somebody with proprietary BMW scanning capabilities. That'll point you in the right direction. It doesn't sound to me like limp mode with the power steering shut-off.
03-12-2015, 07:25 PM | #6 |
NYC ALIVE
32
Rep 646
Mine was a battery issues. def check your battery
NYC ALIVE - Founder
Facebook - NYC ALIVE E90 335xi |Blackline Taillights | 35% Tints | Matte Black Grille | M-Tech Rear | M3 Rep Front | VRSF DP's | Borla Cat-Back Exhaust | JB4 G5 | KW V3's | |
03-23-2015, 05:03 PM | #7 |
Борис
31
Rep 505
Could be the cable running to the fusebox but I dont think they had these problems for the newer ones.
Check battery for sure.
07 SG 335i GONE!
COBB - Burger Motorsports -Ultimate Racing - Evolution Racewerks - TiAL- AMS In Winter Mode - Dunlop Wintersport 3D/Sport Edition Wheels |
03-24-2015, 10:47 AM | #8 |
Nomore
149
Rep 793
Your most likely on the original battery. And its about that time for a nee one. So i would def look into that first.
Now when you say the car cuts out. Does the engine actually stall and shut off? Or it goes into limp mode and you lose power steering? I know my car has the regular non active steering. So the only way for me to lose power steering is the engine actually shutting off therefore stopping the power steering pump from pumping. Maybe you have active steering and the fault is shutting it down for safety. |
03-24-2015, 11:03 AM | #9 | |
Rep 66
