01-04-2015, 08:55 PM | #1 |
Rep 1,789
Drives: wife crazy
Garage List 2019 Ford Raptor [0.00]
2016 Porsche 991.1 ... [0.00] 1987 Chevy Camaro I ... [0.00] 1972 Chevy Corvette [0.00] 1999 BMW M3 race car [0.00] |
TPMS for track only wheels/tires
Are you guys bothering to put in TPMS sensors on your track wheels?
I assume the dash just gives you a warning light? Does the car do something stupid if you don't have them in like limit your settings (DSC off, sport+, etc.)? Thanks
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352 Road course laptimes for Porsche 911 991.1 GTS 7MT WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889 |
01-04-2015, 10:26 PM | #2 | |
Rep 1,997
i'd be fairly certain that you could save the money, live with the error light and check pressures before/after sessions and be just fine. since you thought enough to question it, i guess i'd wait til someone can chime in who knows for sure. i'd put money on it being fine, but not as much as it would take for you to get your tires removed, TPMS installed and tires reinstalled just in case i were wrong. **edit-addition … i'll probably do TPMS because i won't go R comps just yet and may end up driving them on the street a little now & again.
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
01-05-2015, 07:55 AM | #3 | |
Rep 1,165
Bish |
01-05-2015, 09:08 AM | #4 |
Rep 1,563
tpms is likely going to bitch at you for pressure too low anyway if you run aggressive tires that like low pressures. I have to start at 28-29psi cold sometimes. Save your money.
01-05-2015, 11:39 AM | #5 |
Rep 2,997
If you buy the wheels/tires as a package, I believe you get an OEM TPMS sensors for $40/wheel.
You do not need them on track wheels/tires. It's not like this was common tech 10 years ago, and track wheels/tires you are probably going to be checking and dialing in more often. But I think the more pertinent question is: Is $160 (I believe) worth it for you to be able to see from your dash real-time tire pressure and tire temps in a track setup AND avoid having a light on the dash for those days? |
01-05-2015, 11:07 PM | #6 |
Rep 1,789
Drives: wife crazy
Cheapest I'm seeing is $295 for set of 4?
I'm inclined to leave them out. The tire shop charges an extra $10 per wheel when changing tires since there are sensors to "rebuild". Would save there too.
01-13-2015, 08:03 PM | #7 |
Rep 8,075
Drives: 11 E90 M3 Individual
If you could get accurate tire pressures per corner, I would be running TPMS. E9X's don't have that so I never bothered installing TPMS on track tires.
They also tend to fail due to heat front track use.
2018 F30 320iX Melbourne Red
01-13-2015, 08:51 PM | #8 | |
Rep 1,789
Drives: wife crazy
Actually it's less annoying than having the TPMS sensors still in and getting the low tire pressure warning on the way home from track as the tires cool off.
01-13-2015, 08:55 PM | #9 | ||
Rep 8,075
01-22-2015, 06:36 AM | #10 |
Rep 570
Comes down to individual preference and cost. Personally, I wouldn't mind the additional intel of knowing I have a puncture/slow leak before I encountered it during my next lapping session. You'd discover a flat pretty easily, but a slow leak/puncture might be more difficult to spot. The TPMS would pick it up.
For reference, I've done 70+ track days on my E90 w/TPMS sensors (and changed tires five times). TPMS worked flawlessly and never had to change a sensor. |
01-22-2015, 08:53 AM | #11 | |
Automobilist
395
Rep 2,632
01-22-2015, 02:32 PM | #13 |
Rep 1,086
Me too, cheap insurance. Although not entirely necessary, TPMS saved me once as I decided to pit early due to the warning light. I had a slow leak in one of the valves and had lost 10psi during half the session. Although you'd think you could feel this in the way the car handled, it wasn't apparent. If that tire came off the rim in the oval at 150mph, it would have been bad for me.
01-22-2015, 07:17 PM | #14 |
Rep 3,422
Also in the "might have saved my ass" group. Drove into town at lunch last season after 3 morning sessions. Had my pressures dialed in. Started up to head out for the first afternoon session and got the tpms warning for my front right. Sure enough it had dropped like 8-9 psi. Checked again mid-way through the session and had lost another 4-5. Could have been ugly.
So as above, I consider it a worthwhile safeguard for if/when you forget to check the pressures, or you've got them dialed in for the day and no longer feel the need to monitor every session. I've run the same set of track wheel tpms for about 3 years with no issues.
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
11-02-2018, 11:48 AM | #15 |
/M Enthusiast
1599
Rep 1,618
I put the TPMS in my track wheels. I always have the tire pressure displayed while I'm on the track. I can glance over and see the tire pressures and temperatures while on straights or post session.
11-02-2018, 12:09 PM | #16 |
Rep 2,711
MaynardZed1231.00 mcvaughan704.00 |
11-07-2018, 09:00 PM | #17 |
Rep 1,239
TPmS
Yes, I run TPMS on my dedicated track wheels. Auto Club Speedway (ACS) has a roval were high horsepower cars can reach 165 mph "not me" before turning infield. Believe me, you'd want to know what's going on with your tires before entering that roval.
2016 Hellrot F80 M3|JRZ RS Pro with Swift Springs 550/750 spring rates l AP Radical 5000R 9668/9449 lSpiegler SS LinesI DS1.11I Eisenmann DP|MPE Catback|18" Forgeline GS1R 18x10 et 22 and 18x11 et 44 NT01 275/35/18 and 305/35/18| Forgeline GTD1 18x10et43 SquarelM Performance Lip/Splitter|IND aesthetic mods|Dinan Toe Link|Fall Line mono ball conversion kit and upper link kit| Aim Solo 2DL Smarty Cam|Simpson Hybrid|Stilo Offshore helmet.
mcvaughan704.00 |
