01-04-2015, 03:28 PM | #1 |
Rep 554
How do you remove the front BMW badge?
I am prepping my new M235i for a full front end clear film application and would like to remove the emblem so there are fewer seams. Any ideas if it is simply popped it with studs into grommets, clipped or glued on? I tugged a bit and it doesn't give.
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S |
01-04-2015, 04:57 PM | #3 |
Rep 190
You need the plastic straps that boxes come tied in. We use those at the dealership. You just place it under the badge carve the strap deeper towards the center of it and then just pull up. We have been using that method on every single bmw its the easiest fastest way.
01-04-2015, 05:10 PM | #4 |
Rep 554
Thanks guys. Another question, what do you re-attach it with? Is 3M double sided tape too thick?
The Stable
01-04-2015, 05:38 PM | #5 |
Rep 190
01-06-2015, 07:07 PM | #6 |
Rep 554
Well, as it turns out, the hood roundel is attached by a ring of adhesive tape. It took a bit of pulling to pop it off but it worked. The best way to remove it was to loop nylon string around the top and bottom edges and pulling straight up.
The Stable
02-24-2015, 01:12 PM | #7 |
Rep 308
You just made a big mistake. Wish I'd seen this earlier. You may get your roundel back on but it won't stay.
I had to have a new bumper and the BMW certified repair shop told me they would have to put on a new roundel because the old one won't ever stay once it's been removed. |
02-24-2015, 03:42 PM | #8 |
Rep 554
Your tech isn't paid to re-use parts! My Roundel isn't going anywhere!
The Stable
08-04-2016, 05:41 PM | #10 |
Rep 138
08-04-2016, 06:08 PM | #11 |
Rep 554
I popped it off and simply reattached without doing anything. The "stickie" part on the back of the rounded pulled off cleanly from the car and it was able to be reapplied later. (In my case a few days later after the clear bra was applied to the front end.)
08-04-2016, 10:02 PM | #12 | |
Rep 138
I guess I just need to be careful when take it off. so I do not damage the double sided tape for reuse. |
08-05-2016, 08:58 AM | #13 | |
Rep 138
08-05-2016, 04:55 PM | #14 |
Rep 957
you would trim the expel film and then place. You could also replace the tape if you wanted, that's what most body shops do, and then charge you for a new one.
08-05-2016, 06:40 PM | #15 |
Rep 957
08-06-2016, 10:46 PM | #16 |
Rep 554
Yes, right back on the Xpel. It's going nowhere. I even blow the moisture out from underneath with an air compressor after weekly washing.
The Stable
08-30-2016, 04:07 PM | #17 |
Rep 8,942
Thanks for the good pics, very helpful. If I close the deal on a new vert this week will be ordering a new custom roundel was wondering if I should install myself or have the dealer do it. This seems easy enough.
09-01-2016, 12:12 PM | #19 | |
Rep 8,942
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
09-02-2016, 06:37 PM | #20 | |
Rep 554
Good questions, I wondered the same thing. But it's easier than you imagine!
The Stable
09-08-2016, 04:57 PM | #21 |
Rep 8,942
Great, thanks again for the help. Trying to get a car to match dad's 2006 330ci (which has 32k miles if you can believe it). Got him a custom roundel made with his initials instead of BMW, I wouldn't necessarily just do the same for mine but since he'd get a huge kick out of it I probably will. Now if these thieving bastards at the dealership will just send me my paperwork...
