01-03-2015, 12:54 PM | #1 |
Rep 85
Coding Speed Limit Info (8TH)
My M235i came with speed limit info and I figured it's most likely just software to enable on my buddies 435i. He as well has Lane Departure Warning and Collission Detection like my M235i.
I edited the FA to add 8TH and VO coded KAFAS2, FEMBODY, HU_NBT AND KOMI as I figured those were the potential ECUs it may effect. The option is now available in iDrive and it shows the 3 dashed lines as it does before it reads any speed signs... but nothing ever gets detected and displayed in the instrument cluster or HUD. I did a bit of googling and read that an FSC code may be required. Is there a way to generate and install the FSC code via Esys? I remember reading something about generating an FSC code for nav updates... but have never done it. Are there any other ECUs that need to be VO coded for this to work? Is there any way to find out either of these answers given that my car has this feature from the factory? Last edited by sputman; 01-03-2015 at 01:51 PM.. |
01-03-2015, 05:25 PM | #2 | |
Rep 5,262
and select SVT - cafd, load your svt and then select 8th it will show all the ecus affected.... for my car were but i don't have the KAFAS camera so if you do it against your svt it might have additional stuff <<< CAFD_00000794.caf.011_033_013 (FEM_01) >>> FEM_01 > LaMaster1 3073 > LUT_FLC_FORWARDLIGHTING_Y = F020Codierwert ohne AFS FEM_01 > PfRainLightSensor 3130 > REGENSENSOR_INTERVALL = aktiv FEM_01 > PfRainLightSensor 3130 > RLS_LIN_VAR = RLS <<< CAFD_00000DED.caf.003_009_015 (HU_NBT) >>> HU_NBT > EXBOX 3001 > SPEEDLIMIT_INFO = aktiv HU_NBT > HMI 3000 > SLI_NAVI_DISPLAY = nicht_aktiv <<< CAFD_000009C8.caf.006_000_031 (KOMBI L7_MID) >>> KOMBI L7_MID > Anzeige_Konfiguration 3000 > SPEED_LIMIT = aktiv KOMBI L7_MID > ERM_Konfiguration 3004 > BRIG_SURR_APPL = aktiv KOMBI L7_MID > ERM_Konfiguration 3004 > BRIG_SURR_TIMEOUT = aktiv KOMBI L7_MID > ERM_Konfiguration 3004 > RCOG_TRSG_APPL = aktiv KOMBI L7_MID > ERM_Konfiguration 3004 > RCOG_TRSG_TIMEOUT = aktiv KOMBI L7_MID > ERM_Konfiguration 3004 > STAT_FAHRLICHT_TIMEOUT = aktiv KOMBI L7_MID > KI_Dimmung 3007 > DIM_RLS_NACHT_AUS = mit_rls KOMBI L7_MID > KI_Dimmung 3007 > DIM_RLS_NACHT_EIN = mit_rls |
01-03-2015, 05:28 PM | #3 |
Rep 5,262
for reference this is on an F10 with kafas:
<<< CAFD_00000C18.caf.014_078_002 (DSC_Premium) >>> DSC_Premium > Applikationsparameter 3009 > CCC_CoCoIvx = wert_00 DSC_Premium > Applikationsparameter 3009 > CCC_CoMPerm = wert_00 DSC_Premium > Applikationsparameter 3009 > CCC_CoMPermDTC = wert_00 DSC_Premium > Applikationsparameter 3009 > CCC_CoPCCC = wert_00 DSC_Premium > Applikationsparameter 3009 > CCC_CoWeakAy = wert_00 DSC_Premium > Applikationsparameter 3009 > CCC_CoWeakvx = wert_00 DSC_Premium > Applikationsparameter 3009 > CCC_fLwDyn = wert_00 DSC_Premium > Applikationsparameter 3009 > CCC_MLCay = wert_00 DSC_Premium > Teillisten 3007 > Teilliste_CCC = wert_00 <<< CAFD_00001148.caf.000_021_002 (Kafas2) >>> Kafas2 > SLI_CODING 3010 > NPI_ON_OFF = F010 Kafas2 > SLI_CODING 3010 > SLI_ON_OFF = F010 <<< CAFD_00000DED.caf.003_009_015 (HU_NBT) >>> HU_NBT > EXBOX 3001 > SPEEDLIMIT_INFO = aktiv HU_NBT > HMI 3000 > SLI_NAVI_DISPLAY = nicht_aktiv <<< CAFD_00000069.caf.010_001_049 (KOMBI L6 BO) >>> KOMBI L6 BO > ERM_Konfiguration 3004 > RCOG_TRSG_APPL = aktiv KOMBI L6 BO > ERM_Konfiguration 3004 > RCOG_TRSG_TIMEOUT = aktiv KOMBI L6 BO > PIA_Einheiten 3008 > KI_PIA_SPEED_LIMIT = aktiv |
01-04-2015, 12:49 PM | #4 |
Rep 85
Nice tool, thanks for the link. I got lucky and guessed the right 4 ECUs. I guess an FSC code is definitely required. Any hints on that side of things?
FYI, this is what was returned for an F20 chassis with a November 2014 build.... <<< CAFD_00000794.caf.012_034_013 (FEM_01) >>> FEM_01 > LaMaster1 3073 > LUT_FLC_FORWARDLIGHTING_Y = F020_ohne_AFS FEM_01 > LaMaster2 3074 > C_HBA_CAM_POS_Z = F020_KafasLow FEM_01 > PfInternalMirror 3120 > PF_INMI_LIN_VAR = nicht_aktiv [Default] FEM_01 > PfRainLightSensor 3130 > REGENSENSOR_INTERVALL = aktiv FEM_01 > PfRainLightSensor 3130 > RLS_LIN_VAR = RLS <<< CAFD_00001148.caf.000_023_003 (Kafas2) >>> Kafas2 > SLI_CODING 3010 > NPI_ON_OFF = F15_F020_F025_F030 Kafas2 > SLI_CODING 3010 > SLI_ON_OFF = F15_F020_F025_F030 <<< CAFD_00000DED.caf.003_012_025 (HU_NBT) >>> HU_NBT > EXBOX 3001 > SPEEDLIMIT_INFO = aktiv HU_NBT > HMI 3000 > SLI_NAVI_DISPLAY = nicht_aktiv <<< CAFD_000009C8.caf.006_002_033 (KOMBI L7_MID) >>> KOMBI L7_MID > Anzeige_Konfiguration 3000 > SPEED_LIMIT = aktiv KOMBI L7_MID > ERM_Konfiguration 3004 > BRIG_SURR_APPL = aktiv KOMBI L7_MID > ERM_Konfiguration 3004 > BRIG_SURR_TIMEOUT = aktiv KOMBI L7_MID > ERM_Konfiguration 3004 > RCOG_TRSG_APPL = aktiv KOMBI L7_MID > ERM_Konfiguration 3004 > RCOG_TRSG_TIMEOUT = aktiv KOMBI L7_MID > ERM_Konfiguration 3004 > STAT_FAHRLICHT_APPL = nicht_aktiv [Default] KOMBI L7_MID > ERM_Konfiguration 3004 > STAT_FAHRLICHT_TIMEOUT = aktiv KOMBI L7_MID > FZG_Ausstattung 3003 > ANZEIGE_NPI = nicht_aktiv [Default] KOMBI L7_MID > KI_Dimmung 3007 > DIM_RLS_NACHT_AUS = mit_rls KOMBI L7_MID > KI_Dimmung 3007 > DIM_RLS_NACHT_EIN = mit_rls KOMBI L7_MID > PIA_Einheiten 3008 > KI_PIA_SPEED_LIMIT = aktiv |
01-04-2015, 04:08 PM | #5 |
Rep 5,262
you will probably need to buy the FSC code... ask here http://www.bimmerfest.com/forums/forumdisplay.php?f=175
05-29-2015, 11:35 PM | #6 | |
Rep 37
you guys may be interested in this http://f30.bimmerpost.com/forums/sho....php?t=1132862 |
04-19-2016, 03:00 PM | #7 |
Rep 7
can this be done on a F46 uk model
just read this and it looks great .
can this be done in my 2016 gran tourer F46 which has got 1) navigation plus package (ZNQ) 2)technology pack (ZOJ) 3)driver comfort package(ZOJ) ive got the HUD but it doesnt show the max speed limit ,it will show the collision warning with a red car when you approach are stopping car ,i assume it has got the front camera which is needed for the display of the speed limit . thanks |
04-19-2016, 03:28 PM | #8 |
Rep 7
04-28-2016, 02:03 AM | #9 | |
Rep 1
Im only new here in this forum. Just wanted to enquire. Have You managed with this speed limit info? I bought the same car and Im also looking to get this added to my BMW. I was searching and can't find the right answer. Please let me know. |
06-06-2016, 01:48 PM | #11 |
The Schwab
473
Rep 1,605
Drives: 2020 AW M340xi
03-27-2019, 09:02 AM | #13 |
Rep 6
Mason Hatcher1039.00 |
