12-16-2014, 05:54 PM | #1 |
Rep 4,509
Remus front and centre section and MPE back box.
http://www.remus.eu/0880140300-cat-b...r-2-parts.html
Considering a resonator delete and like the sounds of Remus front/centre pipe, incl its twin pipe section a la akrapovic, amytrix, supersprint etc..... Spec says slightly larger tube diameter (84mm v 80mm) but believe this can be sorted by suitable sleeve or coupling to mate the MPE to it. Anyone else tried anything similar ?
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. Last edited by Bee Pee; 12-16-2014 at 06:19 PM.. |
11-23-2016, 11:27 AM | #2 |
Rep 4,509
Update:-
Swapped out standard midpipe on my m135i and now have Remus midpipe between pre-installed BCS hi flo cat DP and MPE. Yes it's feasible as in it was a bolt-off; bolt-on with no trimming/cutting required. Initial thoughts In comfort < 1/2 throttle - same as before. Above that sounds "purer" and "cleaner" - anyone who has swapped from cast headers to tubular manifold should no what I mean. No drone. Sport / sport + - best way to describe the sound is more rorty and blends well with added drama from my CAI and associated plumbing upgrades ..Sounded epic before and this takes it up notch without being unruly. 2 weeks in:- As with MPE, Remus midpipe is getting better with miles. I'm getting more "bark" in the lower to mid range and from inside the car the mid to upper range "howl" sounds clearer ie less fussy. Went for a swift blast with a pal and took some footage - here's a taster... https://m.facebook.com/video_redirec...ment&__tn__=FR Favourite mode is comfort throttle, AT in manual and JB4 canflap open BP
Current '22 X3M LCI.. Last edited by Bee Pee; 11-24-2016 at 04:02 AM.. |
SerenVoX146.00 |
11-24-2016, 04:01 AM | #4 |
Rep 4,509
Current '22 X3M LCI.. Last edited by Bee Pee; 11-26-2016 at 11:55 AM.. |
12-02-2016, 04:02 AM | #5 |
Rep 4,509
Shot with a smartphone- but gives an idea of how it sounds - BCS hi flow cat DP + Remus midpipe + MPE
Remus midpipe is getting better and better as the miles rack up....
Current '22 X3M LCI.. |
