11-18-2014, 05:37 AM | #1 |
BimmerPost Supporting Vendor
5743
Rep 78,076
JBSPEED/Painted Key Hole Cover
The F8x painted key hole cover is the perfect addition for those looking for a clean, uninterrupted appearance. The covers utilize an original BMW OEM core, and by painting these OEM parts at our own in-house paint facility, we ensure a nearly perfect paint match every time. We offer almost all factory BMW colors, including BMW Individual.
The painted key hole cover is designed as a replacement for the original factory surround. We recommend installing the key hole cover on the original lock cylinder. By installing the cover on top of the lock cylinder it provides an emergency access point in the event the battery is drained. Price: www.jbspeed.com or pm/email me Email: crazymomo1028@gmail.com Installation Guide Tool(s) Required: Torx 25 Step 1: Now for the fun stuff. When you open the door you will notice there is a rubber plug located at the top of the door parallel with the door handle. Remove this cover. Step 2: With the rubber plug removed you will notice an opening. Using the Torx25 driver unscrew the Torx bolt that is set within the opening. Step 3: Upon removing the Torx bolt patiently wiggle the lock cylinder from the door. Step 4: Now that the lock cylinder is out of the door the goal is to remove the factory cover. The cover is held in place by 2 plastic tabs, one on each side. Use a pick or a smaller screw driver and carefully pry the tabs upward. Do not apply too much force! You simply need to move the tab enough to release the lock cylinder Step 5: Now that the lock cylinder is removed from the cover you are now able to install the IND key hole cover. This cover simply slides over the cylinder and is secured with the same tabs. IMPORTANT! When placing the cover over the lock cylinder the tabs may not effortlessly slide into place. Apply pressure on the flat portion of the tab until they are seated properly. Last edited by JBSPEED; 11-21-2014 at 02:31 AM.. |
11-19-2014, 08:53 PM | #2 |
5743
Rep 78,076
11-22-2014, 06:00 PM | #3 |
5743
Rep 78,076
11-25-2014, 11:54 PM | #4 |
5743
Rep 78,076
11-29-2014, 07:19 PM | #5 |
5743
Rep 78,076
12-02-2014, 09:34 PM | #6 |
5743
Rep 78,076
12-11-2014, 10:06 AM | #7 |
5743
Rep 78,076
12-19-2014, 05:47 PM | #8 |
5743
Rep 78,076
