Logic 7 Wiring - Help needed (retro fit)
11-03-2014, 02:39 PM | #1 |
Rep 201
Hi All,
Currently going through the Logic 7 Retro fit process on my 330D E92 with CIC I drive. I have the OEM Logic 7 Wiring harness but not too sure where the amp gets its power from? From the wiring diagram below I understand the Positive power wire is Red & Grey but I'm not 100% sure where this is supposed to run to from the harness on the amp. Also when I've wired amps in the past they normally need a remote start, is this not the case with the Logic 7 i.e the power wire is some how connected in with the CIC system? The power wire seems as long as the front dash speaker wire so I assume it wires in somewhere round there. Can anyone with logic 7 confirm? Can I just run this to the battery in the boot with an inline fuse? If so what rating of fuse? Hope someone can help |
11-03-2014, 03:02 PM | #2 |
Rep 9,097
Goes to the fuse box.
In Uk cars, wiring should run on the passenger side.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
11-03-2014, 03:12 PM | #3 |
Rep 201
11-03-2014, 03:14 PM | #4 | |
Rep 9,097
You should look at the fuse number of navigations / amp and should be able to find. There should be three or four fuses for navigation and one of them is for amp.
