E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > e90 pre-Lci Halogen to pre-Lci Xenon help needed
      10-23-2014, 03:25 AM   #1
68whiskey
Drives: 2008 328i 4 door / Black
So my 328i got hit by a bus the other day and is in the body shop now. I have a pair of Pre-Lci Xenon headlights w/ AHL (bulbs,ballasts & moduls) that I wanted to upgrade to later , but I might have to do it sooner. I plan to use the xenons only , no intention of using the AHL feature at all. My goal is to wire these or find a harness so I can just drop them off at the shop with the Low/High & corner lights working. Ive search for a quite a bit and cant find anything particularly related to this. Ive seen other headlights here wired for plug and play drop in , this particular DIY http://www.e90post.com/forums/showth...non+conversion was what I needed but all the pictures are gone , I tried search for this mythical Beta1 harness so i can drop in the headlights but i cant even find that.
Is there anyone in that can shed some light on my dilemna? I am In san diego and can work with someone local or pay for local coding.
      10-23-2014, 04:29 AM   #2
GreaseJunkie
Drives: 2006 E90 330i Black Sapphire
Not 100% but I believe you'd still need to code it to function properly. Are you willing to part with one of your AHLs?
      10-23-2014, 04:37 AM   #3
68whiskey
I thought so too , but then I saw this for sale listing in which he has these as Plug & play converted
http://www.e90post.com/forums/showthread.php?t=1044437
If you are talking about the AHL modules , id be willing to part with them after I get the car headlights going. I dont want to find out I might need it later
      10-23-2014, 07:10 AM   #4
GreaseJunkie
Maybe this thread will help?
http://www.e90post.com/forums/showthread.php?t=912413
      10-23-2014, 07:13 AM   #5
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Drives: 06 SGM E90, 15 BSM E84
You have to add Adaptive Xenons ($522) to the Vehicle Order, and manually disable the Adaptive checks that will show up in FRM. This will eliminate the adaptive (swiveling) feature of the headlights though
| 3-IM | AA Headers | Eurocharged Stage-3 | BMW PI |
      10-23-2014, 07:34 PM   #6
68whiskey
I wasn't asking about this , I was asking about the wiring for the xenons into a halogen car. I have ground something according to the other thread and I'm looking for wiring information so I can just get the lights working. I'll deal with the errors later
      10-23-2014, 07:46 PM   #7
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Speaking from experience, that isn't the ideal way to do it as you can damage your FRM module. But good luck I guess.
Code first.
      10-24-2014, 05:55 PM   #8
00e46sedan
00e46sedan's Avatar
Drives: 16’ F13 640i M Sport
I believe u can do a tap splice from the (female) connector, not from your headlight (male) connector. See if this helps. Gl just to give u an idea.
1 2 3 4 5 6 7
E A B C D
A = Gound
B = Low Beam
C = No Pin
D = Angel Eye LED Rings = Parking light
E = High Beam stay on for Xenon model
1 = Signal Light
7 = High Beam halogen for Halogen model
      11-03-2014, 02:59 AM   #9
68whiskey
1 2 3 4 5 6 7
E A B C D
A = Gound
B = Low Beam
C = No Pin
1 = Signal Light
that is definitely the direction I am looking for. Which wire taps to what is where im drawing a blank? Would I take a wire from the wiring harness and run it directly into the wiring inside the head lights??
      11-03-2014, 10:56 AM   #10
00e46sedan
00e46sedan's Avatar
Your gonna tap two wires, for me it was E and 7. I say try that and go from there, keep me posted
Also everything your doin on the wiring harness itself, not from headlights, first try the E and 7
e90post
