2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning M235i EWG for JB4 install help
      10-17-2014, 06:15 PM   #1
camMCLEAN
camMCLEAN's Avatar
40
Drives: F80 M3 ZCP
Has anyone installed this? I have an 8AT and I was warned its a tight fit but wow! I have been working on this damn waste gate connector clip for 2 hours now and I can't remove it!
Does anyone have any pointers? Or what they used to reach it? Please help haha
      10-18-2014, 12:09 PM   #2
G-Mann
G-Mann's Avatar
413
Drives: M4CX
Wish I could help, just started researching this myself. I take it you did not have any issues installing your FF harness?
I just switched to map 2 without the EWG and FF which will limit my peak boost so I might pick up 1psi 8-12 whp. If I don't feel a difference I will roll back to map 1 and contemplate ordering the EWG and FF for this install which looks to be a PIA due to location and access.
Time for my first test spin on map 2
2022 M4 Comp X
2021 M440ix - Sold
2015 M235 - Sold
      10-18-2014, 12:16 PM   #3
snodgrass23
snodgrass23's Avatar
Drives: 2015 EB m235i
I had a tough time with it too. What I ended up doing was making a custom tool for it. I bent a screw driver around into a shape so that I could hook it around from behind the plug and get it under the clip.
aFe Momentum Intake, Dinan springs
      10-18-2014, 01:47 PM   #4
Melinko
Melinko's Avatar
South Africa
Drives: BMW M340
Tie a small screwdriver too you wrist with a piece of string then menover it into position with you fingers, I think I squeezed in my other hand to pull while pressing the clip with the screwdriver.
      10-19-2014, 07:02 AM   #5
snodgrass23
I case it helps anyone, this is what my screwdriver looks like after I bent it. This allows me to come in from behind it, get it under the clip and then pull of the connector.
      04-07-2015, 02:38 PM   #6
Shankska
Shankska's Avatar
Drives: 2019 BMW M2 Competition
2019 BMW M2 Comp  [0.00]
2016 BMW M2  [0.00]
2014 BMW M235i  [0.00]
+1 nice idea
2019 F87 M2C, Long Beach Blue, Exec, 6MT
2016 F87 M2 - Sold 9/2018
2014 F22 M235i - Sold 5/2016.
      04-09-2015, 09:55 PM   #7
M_Proper
Drives: 2015 M235i
And make sure you put some heat shield tubing over those EWG harness wires and zip tie them as far away from the exhaust components as possible. It gets HOT down there and the aluminum heat shields opposite the engine are brutal too.
      04-13-2015, 12:49 PM   #8
rmshashaty
rmshashaty's Avatar
Drives: m235i
You need to have a plan when you tackle it, took me 20 min. Need a long rod or screw driver to push it off the clip from the front of the car while you press the release on the clip. It will slide right off.
2014 EBM/CRD M235i JB4, EWG board, FF Wires, EWG Wires, BMS Intake, ER DP, ER CP, E50, Map 7.
      04-13-2015, 12:51 PM   #9
Shankska
Shankska's Avatar
2016 BMW M2  [0.00]
Do you have a picture of your wire job?
I just checked under my hood and my wire loom has melted from the heat. Thankfully my wires are still good, but had to re wrap the cables with new wireloom.
I tried zip tying them far away, but not much room down there. Maybe the wireloom I obtained is not the best...
Reid252.50
      04-13-2015, 06:22 PM   #10
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
Welcome to Burger... where you pay to play at your own risk !!
      04-13-2015, 06:56 PM   #11
Shankska
Shankska's Avatar
2016 BMW M2  [0.00]
Thanks for the encouraging words haha. Guess I need to return it
      04-13-2015, 07:44 PM   #12
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
sorry mate I should be more positive .... I hate flogging a dead horse tho !!
      04-13-2015, 07:48 PM   #13
Shankska
Shankska's Avatar
2016 BMW M2  [0.00]
No worries. What do you run?
      04-13-2015, 07:50 PM   #14
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
Nothing Now as I have Started putting my car back to standard for sale !! But I was running Manhart
      04-14-2015, 03:45 AM   #15
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Chaddy,
What's coming next after your M135i ?
BP
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      04-14-2015, 04:51 AM   #16
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
M2 mate ! FTW
Originally Posted by Bee Pee View Post
Chaddy,
BP
      04-14-2015, 09:49 AM   #17
M_Proper
Drives: 2015 M235i
I'll post some pics after work today.
      04-14-2015, 10:14 AM   #18
Shankska
Shankska's Avatar
2016 BMW M2  [0.00]
M2 mate ! FTW
I plan on ordering one in November as well
      04-14-2015, 10:15 AM   #19
Shankska
Shankska's Avatar
2016 BMW M2  [0.00]
ok thank you! and your wireloom hasnt melted at all? Where did you purchase yours?
      04-14-2015, 11:50 AM   #20
BD_F22
BD_e92
Drives: 2015 m235i xDrive
You shouldn't try to scare people from purchasing the JB4 just because it didn't work out for you or you had a bad experience. The reason most problems seem to arise from JB4 users is 1) simply because there are way more JB4 users on every BMW platform than any other tune available. Or 2) install was done incorrectly and then problems arise because consumers want to purchase it and then not put in the work to data log and make corrections. I would say the JB4 is the perfect tune for those who want a more user adjustable configuration and the ability to increase aggressiveness at their own will. Some of us want to push the envelope a bit and see what these cars can truly handle others want a simple tune and leave it. Without that end user adjustability the n54 would have never been able to acheive 800+ whp.. I have been a JB4 user for years going back to my e92 335 and I also install a ton of them for customers and perform BMS backend flashing on the n54 and there is a reason they hold almost all records.
      04-15-2015, 12:47 PM   #21
kd0t
Drives: M235i
+1
Nothing but good things to say about BMS
      04-15-2015, 02:49 PM   #22
Mike@N54Tuning.com
Joint Chiefs of Staff
Drives: 2007 335i, 2015 M3
OP if you need assistance I'd suggest using BMS' support forum or emailing their tech support department. The EWG wires need to be routed away from the manifold. I've not heard of wires melting before I read this thread so I haven't paid close attention to that routing but if you post photos on BMS' forum I'm sure they can help you out.
Alternatively the JB4 is the only tuner that offers EWG control. You could not run the EWG wires and not have to worry about their placement and all that extra horsepower.
Mike
2addicts
