08-03-2014, 03:18 PM | #1 |
Rep 6,690
Golf Tee Mod?
I know that the infamous "golf tee mod" has long been popular with BMW's that have vacuum operated exhaust flaps. Has anyone who owns an F8X found a way to wire the exhaust flap open so that it's at it's loudest setting all the time?
Has anyone who owns one really had a desire to? Just curious. |
08-03-2014, 03:46 PM | #4 |
Rep 1,418
08-03-2014, 05:04 PM | #7 |
Rep 1,982
08-03-2014, 05:04 PM | #8 | |
Rep 969
08-03-2014, 05:44 PM | #9 |
Rep 3,899
That's correct. Set engine response to Sport + and the valves stay open. Easy mod!!!
2014 AW F80 M3 DCT
2011 AW E90 M3 DCT - Sold 2010 JZB E90 M3 DCT - Sold 2009 6MT E90 LCI 335i M -Sport - Sold |
08-03-2014, 06:00 PM | #11 | |||
Rep 1,982
They still close in sport+ mode. Here is quote from interview with bmw m3/m4 acoustic engineer, Rainer Drees. "For instance, if you select the COMFORT mode, the exhaust valves are fully closed in the lower revs ranges. If there is a greater load demand at higher engine speeds, they open up. When driving with a constant load in COMFORT mode, the valves generally remain closed to achieve a maximum level of everyday comfort over long distances. In SPORT and SPORT PLUS modes, other engine characteristics are selected for controlling the exhaust valves. At lower gears, the exhaust valves are always open, while when higher gears are selected under constant driving conditions, they are closed; however, if the load conditions change accordingly, they open up in a flash. There are also ranges in which we have chosen to close the valves, for instance at low engine speeds in high gears. In these ranges, which are frequently selected in the automatic mode of the M DKG Drivelogic for driving at maximum efficiency, the exhaust tract in turbo engines would have a tendency to drone if there were no damping." |
08-03-2014, 06:22 PM | #13 |
Rep 1,997
08-03-2014, 08:02 PM | #14 | |
Rep 480
08-03-2014, 08:46 PM | #15 |
Rep 3,899
Exactly. In lower gears it's open - good. While cruising its quieter- good. While cruising and you put your foot down it's louder- good. Can't see the issue at all.
2014 AW F80 M3 DCT
08-07-2014, 08:57 AM | #16 |
Rep 311
Good for the DCT guys to just always dump it into Sport+. But as a 6MT guy, I want the option to be able to drive in Sport (still retain Rev Matching), while still having the flaps always open.
Would like more information or a (DIY) on where to disconnect when flap is open to keep it open. Anyone successfully done this yet? ****EDIT**** JUST SAW THE DIY POP UP IN THAT SECTION OF THE FORUM. THANKS!!!!! |
08-07-2014, 04:11 PM | #17 |
Rep 2,991
http://f80.bimmerpost.com/forums/sho....php?t=1006077
Thanks. Anyway, it makes a big low RPM difference. I covered the plugs with a rubber glove and tied them off, and tucked them up under the heat shields. |
09-07-2014, 09:28 AM | #18 |
Rep 13
Just unplugged mine. Most definitely makes a difference. You can have it in Eco mode and it still barks.
I didn't experience any drone and it eliminates the start up rattle. |
09-07-2014, 12:25 PM | #19 |
Rep 3,161
unplug the connectors and if the valves are shut, grab a long screw driver and push them open. Or you can put it in sport plus and go unplug the connectors. Sounds good!
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/ SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/ SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/ |
12-20-2014, 02:50 PM | #20 |
Rep 1,268
I have mine unplugged with the valves open and it has a lot more character but there is a drone when cruising on the freeway which can be annoying.
Past: BMW (22 G20 M340i, 15 F80 ///M3, 12 E92 335i, 08 E90 335i, 02 E46 325i)
Mercedes-Benz, Porsche, VW, Lexus Present: 24 992 C2 |
03-07-2015, 10:01 AM | #21 |
Rep 649
Has anyone tried unplugging just one...maybe that would be a happy medium. More bark, less drone?
CURRENT///G80 M3CX | Isle Of Man Green | Kyalami Orange | Bi-Color 826M Wheels
FORMER ///F80 M3 ZCP | Yas Marina Blue | Black | DCT | Black 666M Wheels FORMER ///F87 M2C | Alpine White/Orange | DCT | Black 788M Wheels FORMER ///F87 M2C | Sunset Orange/Orange | 6MT | Black 788M Wheels FORMER ///F82 M4 | SSII | Full SO | 6MT | Black 437M Wheels |
10-25-2015, 10:41 PM | #22 | |
Rep 224
Drives: Tesla M3P
