2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Coding light distribution
      07-17-2014, 11:09 PM   #1
Oyinko
Drives: M235i
I have some issues with coding the light distribution on my M235i with premium package (without HBA)
In the spreadsheet, it says coding C_AFS_ENA from nicht aktiv to aktiv. However, I don't have this option
Same issue when I need to code LUT_FLC_FORWARDLIGHTING_Y from 9C 9C B0 to 9C 9C 9C
Any help would be appreciated. Thanks!
      07-18-2014, 12:18 AM   #2
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
just update the werte values
FEM_BODY 3073 C_AFS_ENA "00" "01"
FEM_BODY 3073 LUT_FLC_FORWARDLIGHTING_Y "9C, 9C, B0" "9C, 9C, 9C"
http://f30.bimmerpost.com/forums/att...3&d=1338274757
      07-18-2014, 02:12 AM   #3
Oyinko
Drives: M235i
Thanks. I just done it and I have now the following settings after a restart of the car and Esys
View post on imgur.com
I have done some test and it's working really great in the city. The beam is wider. However, I haven't seen any difference on the freeway. Should I do something more?
      07-18-2014, 08:02 AM   #4
pikcachu
pikcachu's Avatar
1399
you need to go over 68MPH for the one on the freeway to kick in
      07-18-2014, 10:29 AM   #5
Oyinko
Drives: M235i
I was doing 70MPH but maybe it's not easy to see the difference.
      07-18-2014, 07:51 PM   #6
pikcachu
pikcachu's Avatar
1399
ya it might be hard cause it will only point 25% further
but the 30mph change is very noticeable
      07-19-2014, 01:05 PM   #7
HX_Guy
Drives: 2014 BMW M235i
I ran into the same thing, my menu items were different than just "nicht_aktiv" and "aktiv".
Does the description matter any or is it really what the Werte says that's important?
For example I changed the Werte from 00 to 01, but the description stayed as "F020inaktiv, F020disable, etc..."
You can select from the drop down "F020enable" and it changes the Werte to 01 automatically, so I guess that's the same thing as changing form nicht_aktiv to aktiv.
Same on the second part, you can change the Werte value or you can select "F020Codierwert mit AFS" and it changes the values to 9C, 9C, 9C automatically.
      07-19-2014, 01:40 PM   #8
lichenlt
Drives: M235i
Alternatively, an easier way to code the VLD and HBA is to remove 5AP and 8S4 from your FA and then VO code FEM_BODY and KAFAS2. All five entries in these two modules will automatically change to aktiv, but do go back and check if they are.
Also confirm
HU_NBT => 3000 => HIGH_BEAM_ASSISTANT => aktiv
KAFAS2 --> 3050 --> FLA_ON_OFF => aktiv
      07-19-2014, 01:47 PM   #9
HX_Guy
Won't VO coding change all other coding you've done to FEM_BODY? Or am I confusing that with something else?
      07-19-2014, 02:09 PM   #10
pikcachu
pikcachu's Avatar
1399
Yes it will clear all your FEM_BODY coding but if the dealer ever update your software the VLD will still be on... if you FDL code it everything will go away...
just change the werte values... the description will update automatically once you save the file
      07-19-2014, 02:12 PM   #11
pikcachu
pikcachu's Avatar
1399
Also confirm
actually HBA can't really be coded if you don't have the hardware, so that people don't get confused... what can be coded is the anti-dazzle HBA if you have HBA which is removing 5AP like you said and 8S4 for VLD
      07-20-2014, 03:20 PM   #12
HX_Guy
The new coding worked great last night, can definitely see the lights moving once you pass 30 MPH. Cool mod, thanks to those to found this!
      07-20-2014, 09:25 PM   #13
pikcachu
pikcachu's Avatar
1399
      07-21-2014, 02:06 PM   #14
HX_Guy
Anyone know if the headlights can still be adjusted per normal procedure with the light distribution coding? Or does it change how they should be adjusted?
      07-21-2014, 02:15 PM   #15
pikcachu
pikcachu's Avatar
1399
Not sure... i would assume they adjust the same way with the engine off so the VLD doesn't kick in and then VLD on is going to be relative to when the VLD is off
      07-21-2014, 04:34 PM   #16
lichenlt
Drives: M235i
with VLD turned on, the left headlamp is supposed to illuminate more to the left side of the car, right? because it turns to the left when the engine starts and only moves towards the center when highbeam is on or when the vehicle speed exceeds 30mph.
      07-21-2014, 04:43 PM   #17
HX_Guy
Yeah, I believe that's how it's supposed to function.
      07-21-2014, 04:46 PM   #18
pikcachu
pikcachu's Avatar
1399
Yes that's how it's supposed to work
      10-03-2014, 01:02 PM   #19
Oyinko
Drives: M235i
Is it possible to adjust the height of the lights to make the beam lit the road further?
      10-24-2014, 08:56 AM   #20
TB///M3
Drives: 16 ///M3
Yea..i feel the light is aimed too low, anyone know how to code the light a little higher?
      10-29-2014, 09:04 PM   #21
nyeager
Drives: 2015 M235i xDrive
Are you guys definitely noticing the highway mode change at > 68MPH? I've been trying hard to notice it but I can't tell a difference at this point.
      10-30-2014, 04:21 PM   #22
Oyinko
Drives: M235i
I can't notice it either. Anyone know how to adjust the height of the light? definitively too low!
2addicts
