06-24-2014, 07:38 PM | #1 |
Rep 42
The Incredible Missing Modern Safety Feature
Test drove the i3 in Seattle last week, and was thoroughly impressed.
Except...I cannot figure out why BMW does not offer modern safety technology ubiquitous even in low-end cars - Blind Spot Detection. Why does a mid-range Hertz Buick rental have better technology than an i3? |
06-25-2014, 01:31 AM | #3 | |
Rep 10
06-25-2014, 12:52 PM | #4 |
Rep 42
"Blind Spot Detection" automatically lights indicator on left or right side mirror when a car is passing you.
Driving rental car on NY State Thruway in heavy storm with low visibility this winter, I found it to be one of those things that once tried is tough to give up. |
06-25-2014, 01:21 PM | #6 |
Rep 1,061
The issue may be that to do this, you need a constant electrical draw, and it was not deemed worth it for the city car nature of the design (there'd be cars there most of the time in a busy city!). But, if you have the option, it does scan for parking spaces below a certain speed while driving straight. The range of those isn't all that great.
The magic to adjusting mirrors 'properly' is to lean towards the mirror in question, and adjust it so you can just see the side of the car. THen, when sitting normally, it shows you what had been in those blind spots. The only time you may want them tilted in more, is if the rear-view mirror is obstructed by some load you're carrying, and then you need to be able to see directly behind you. Done correctly, you should be able to see three pretty much full lanes., and be able to view someone passing you in the mirror until they are easily visible out your side windows. |
06-25-2014, 09:04 PM | #7 | |
Rep 18,720
06-26-2014, 09:56 AM | #8 |
Rep 3,307
The side windows are the blind spot, at least the rear side windows.. you still need to check regardless of how you set your mirrors and whether or not you have blind spot detection (helpful but not reliable enough to disregard basic driving principles). There is no magic to adjusting your mirrors to eliminate blind spot, you still need to turn your head and look.
06-26-2014, 10:31 AM | #9 | |
Rep 9,160
06-26-2014, 10:55 AM | #10 |
Rep 3,307
not buying it guys, the mirror can't see everything. if you put it close enough to not have the normal blind spot along the side of your car, you're too close and can't see as much further out. As I said, more about the rear passenger window, I suppose convertibles are a different animal. I'll gladly try this and eat crow if you're right.
I do agree that BSM isn't necessary though, especially on this car. I think it's only so useful on any car, if people rely on it too much or let it be distracting. Same thing with lane departure. Test drove an F15 with it and it was so unreliable, I would be 2 feet over a clearly marked, freshly painted center line sometimes before it went off. If people rely on these things, it's more dangerous than not having it. Last edited by chrisny; 06-26-2014 at 11:03 AM.. |
06-27-2014, 02:14 AM | #11 |
Rep 42
Yes, you can adjust the mirrors and eliminate blind spots.
But also, yes, you can pump the brakes and stop a car on ice without antilock brakes. The technology is valuable, it is here to stay, and it will soon be ubiquitous. |
06-27-2014, 05:59 AM | #12 | |
Rep 18,720
So the actual method for adjustment is to lean towards the window so your head lightly touches the window, then adjust the mirror to just see the edge of the side of the car in the inner edge of the mirror. Then lean the same amount towards the passenger side and adjust the passenger mirror in the same manner. It really works, try it. You can actually set the mirrors where half of an approaching car will be in the inside rear-view mirror and the other half will show in the side mirror. |
07-07-2014, 12:20 PM | #13 | |
Rep 3,307
That said, we're all human and sometimes forget to check no matter how responsible we may be, so newer safety features like blind spot detection and lane departure warnings are just another way to help, and just like mirrors and back-up cameras, should never replace simple common sense and basic driving skills. |
07-07-2014, 04:03 PM | #14 | |
Rep 18,720
What the proper mirror placement allows you to do is rapidly scan the rear view to maintain a level of cognizance of how the traffic behind you is moving from lane to lane and approaching or falling away from you. Proper driving technique is constantly scanning the road ahead and behind to keep the best situational awareness. One should keep aware of traffic so that you know when a car is at your left or right rear quarter and can momentarily be out of vision. Ride a motorcycle in traffic and you'll understand. There's a difference between being arrogant and being confident... |
07-07-2014, 05:42 PM | #15 | ||
Rep 3,307
that was my point.. it's the way you're supposed to do it, not a 'trick' no one knows about.
Agreed again, but you missed the point. My point was it would be arrogant (not confident) to suggest the mirrors can be positioned to have zero blind spot, zero need to take a look to your left, however slightly. My point was also that I didn't think you were being arrogant, as you said properly setting up your mirrors doesn't eliminate the need to still turn your head a little and look. |
07-07-2014, 08:09 PM | #16 | |
Rep 18,720
07-07-2014, 08:10 PM | #17 |
newb
Rep 31
BMW figured out a better way
Not sure why we do not get at least the option in the USA, but Euro spec i3s have the outside 1/3 or so of both side rear view mirrors optically expanded to capture pretty much anything that might show up in our typical blind spot. There is something of a dotted line that separates the 1:1 view from the expanded view, and it becomes instantly intuitive. In my opinion, it is a far simpler and more elegant solution to the blind spot problem than an idiot light. My guess is that some moronic USA regulation prohibits its use here, and BMW wisely chose to wait for us to wise up and change our rules rather than add a needless layer of complexity to the fraction of their i3 fleet they sell here.
07-07-2014, 08:14 PM | #18 | |
Rep 18,720
07-09-2014, 05:40 PM | #20 |
Rep 87
this car does not need blind spot detection...if you think it does, you're looking at getting the wrong vehicle
product genius at BMW of Mt. Laurel in New Jersey
96 Volvo 850 Turbo 120k |
07-09-2014, 09:05 PM | #21 |
Rep 18,720
To me, being taught to "never trust your mirrors" just means the person teaching you didn't know how to properly adjust the mirrors and thus couldn't teach his students; so the next best thing? "Don't trust your mirrors."
07-10-2014, 08:22 AM | #22 |
Rep 1,061
The biggest thing is, you really do have to look first! Whether it is via properly adjusted mirrors or physically turning your head, if you keep aware of your surroundings, your chances of getting into trouble are much less. The only times I've had a close call are when you're passing someone on a multilane road, and someone else ends up pulling out to pass into the lane of the vehicle you've just passed, especially if you're passing something like a tractor trailer which was blocking the right lanes for awhile.
I really enjoyed driving in Germany when I lived there...except during the summer when there were lots of tourists. The Germans really take following the rules of the road to heart, so people actually keep right except to pass, and do not pass on the right. Plus, they do follow the right of way rules. Course, there are always the exceptions, but as a general rule...you can be pretty sure the rules will be followed, which makes it less stressful and safer. Their driver training and required knowledge of the rules before they can get a license is vastly more intense and complete than the silly 20-question written test, and short driving test we give people. Given that, it's a marvel that more people aren't injured in vehicular accidents here. I think we have our attitudes and expectations wrong...driving is a privilege, not a right, and it should be earned. |
