      10-06-2024, 07:29 PM   #1
gofairchild323
Drives: 2008 BMW 535i
Exclamation 535 N54 noise from valve cover
I have an lci 535xi that has recently been making a rattling noise that follows rpms seeming to originate from the front of the engine. I am not too knowledgable about the e60 platform, so rather than just digging in to find the problem I thought I should ask knowledgable people. I am attempting to attach a video, but if it doesnt show up, it sounds like marbles are in the timing chain, and comes and goes with rpm and turning it off and on.
[ATTACH]undefined[/ATTACH]
      10-18-2024, 11:02 AM   #2
MetzgerMeister
MetzgerMeister's Avatar
39
Drives: F82 M4
Guessing your car is a manual and that the noise goes away when you depress the clutch?
If so, it's more than likely the throughout/clutch release bearing. I had the same issue on my N54 335i.
To repair, it's a gearbox out job as this bearing is inside the bell housing.
Current: 2016 F82 M4
Previous: F30 330d / E92 335i / E46 318i
      10-24-2024, 07:12 PM   #3
javi_530d
Drives: e60 530d 2005
could it be a loose swirl flaps? on yt there is a channel Bmw Doctor that says how to delete those because it can get lose and go into the intake manifold, and cause damage to the engine, i would check for the swirl flaps
