09-25-2021, 11:07 AM | #23 |
MFJWADE
120
Rep 351
Finally a nice dip into negative DA. Car is asking for a lot of fuel because of the air, trims are tabletopped. I'm at E37 on this run and need to back down in E content and or add meth. I'll be adding meth later this month.
2018 M5 Singapore Grey CCBs/Utku Noa E45 ECU/xHP TCU/PG-Intake/PG-Lower Downpipes
09-25-2021, 11:19 AM | #24 |
Rep 548
Shit man that is good! Proof to my argument with these cars right there… timing is everything! Your hitting great timing through most of the pull and 22 at the top of 5th, with moderate boost. She is definitely moving air with your fuel trims that high. I usually see around 35 maybe 40.
Do you find your timing increases as the da lowers? I’m starting to see that with mine, but I’m not sure if it’s a coincidence or not.. Great runs for no dps and JB4… What meth system are you buying? I’m ordering one too.. snow performance 2.5 I was looking at? Last edited by AngryInch; 09-25-2021 at 11:25 AM.. |
DrivenAgain120.00 |
09-25-2021, 01:56 PM | #25 | |
MFJWADE
120
Rep 351
Going to use the JB4 meth system for its failsafes.
09-26-2021, 07:21 AM | #27 |
MFJWADE
120
Rep 351
Thx man, all of my runs are planned relative to weather. Some runs are at 4am lol #DAhunter
09-26-2021, 09:06 AM | #28 |
Rep 548
09-26-2021, 11:34 AM | #29 | |
MFJWADE
120
Rep 351
This a log of a run in DA1800ft, looks as if peak timing was about 15deg. I ran a 7.12 60-130 here.
09-26-2021, 12:05 PM | #30 |
Rep 548
That is exactly what I am running now low 7s in the teen range like that with 15degree of timing in 5th, a bit higher timing sometimes in 4th.
Maybe it is the DA controlling the timing.. You'd think it would be intake temps, but denser air would cause more combustion pressure, if the octane can handle it. Cooler air is denser... hmmm.. Thanks for sharing, that site is mint! |
09-27-2021, 11:05 AM | #32 | ||
MFJWADE
120
Rep 351
Your 60-130 and traps seem to be inline for your mods relative to your DA. A few tweaks and some better air...
09-27-2021, 11:14 AM | #33 |
Rep 315
this is wild without dowpipes props man.and that da is nuts
2020 BMW m5 with some bmc filters, charcoal filter delete, and Dinan turbo inlets.
Previous BMW model 2018 bmw 340i FBO custom e50 tune 500 wheel |
DrivenAgain120.00 |
09-27-2021, 07:05 PM | #34 | |
MFJWADE
120
Rep 351
09-28-2021, 05:52 AM | #35 | |
Rep 315
09-30-2021, 10:56 PM | #36 |
Rep 107
2020 Base model w/exec, no sunroof, steel brakes
Dinan inlets BMC Filters JB4 Map 1 on 93 oct Remus exhaust 789m wheels with 285/295 PS4s Launch control, MDM 4wd, normal tire pressure Was uphill at the end pretty significantly but this is my best time so far. First draggy since the inlets but also coolest temps I've run in. Temps in the 50's. Car def loves the cool air. |
10-01-2021, 09:59 AM | #38 | |
MFJWADE
120
Rep 351
What was your 60-130 on that run?
10-01-2021, 11:44 AM | #39 | ||
Rep 107
I'll have to try some dedicated 60-130 and see if it can do better. |
10-01-2021, 01:08 PM | #40 | |
Rep 315
and no downpipes wow
10-01-2021, 01:18 PM | #41 |
Rep 315
also the car lets you launch in mdm mode I thought you had to be in fully dsc off to launch
10-01-2021, 02:56 PM | #42 |
Rep 1,597
Was that a question or an answer? Because that's what I asked above and didn't get an answer. According to all "directions", DSC has to be totally off and transmission set to fastest manual setting (but shifts automatically.)
10-01-2021, 04:06 PM | #44 |
Rep 315
a question I was trying to ask him how he got it to launch in mdm mode I was under assumption it had to be in fully dsc off mode sorry
