View Poll Results: I own a...
2008 model and the waterpump failed. 176 14.05%
2008 model and the waterpump is ok. 194 15.48%
2009 model and the waterpump failed. 65 5.19%
2009 model and the waterpump is ok. 195 15.56%
2010 model and the waterpump failed. 18 1.44%
2010 model and the waterpump is ok. 87 6.94%
2011 model and the waterpump failed. 73 5.83%
2011 model and the waterpump is ok. 172 13.73%
2012 model and the waterpump failed. 52 4.15%
2012 model and the waterpump is ok. 103 8.22%
2013 model and the waterpump failed. 23 1.84%
2013 model and the waterpump is ok. 95 7.58%
Voters: 1253. You may not vote on this poll
      02-26-2013, 10:56 AM   #67
JHZR2
Drives: 91 E30, 11 135i cv
Originally Posted by Dackelone View Post
I was at my dealer today picking up some brake rotors for my e39... I asked them how long the electric water pumps last. I told them a friend of mine with an early ('08 or '09) 335i just had his water pump die at 90K miles. And they said... of course... at anything over 60K miles and your on borrowed time. So.... I think 60K or 70K is gonna be when I change mine.
Granted it is more pricey than a regular belt driven unit, but isnt 60-70k historically (I know, I too have had ones that have gone much longer) a replacement interval for pumps and thermostats?
At my rate, 60k will be a LONG time... Hope they still make 'em by then!!
      02-27-2013, 04:28 AM   #68
yawn
Drives: M2 Competition
+1. I believe it to be relatively an easy replacement job. I have not really seen a DETAILED DIY. Just that one DIY with a few pics here and there. I would really like to see someone do a step by step DIY.
Btw... you can buy a new BMW (dealer)pump & thermostat from one of our forum sponsors for under $500 for both! That is a much better price than $1,200 that some have paid stranded at a dealer in Timbuktu.
I am almost at the right miles to start thinking about doing a waterpump replacement as well. Humm....
Dack
+1
I haven't seen any DIY either... Not having any problems yet, but would like to know how it's done, and IF I can do it.
      02-27-2013, 06:07 AM   #69
Dackelone
European Editor
Dackelone's Avatar
Germany
10607
Drives: N54 e82
Originally Posted by sharkatron View Post
+1
Here are two good DIY's... (on the e90post)...
DIY – Water Pump & Thermostadt Replacement (2007, 335i w/Automatic Transmision)
http://www.e90post.com/forums/showthread.php?t=784416
Pictures: Electric water pump + thermostat replace
http://www.e90post.com/forums/showthread.php?t=347412
      02-27-2013, 06:12 AM   #70
Dackelone
European Editor
Dackelone's Avatar
Germany
10607
Drives: N54 e82
Yup, 60K is about the miles on older BMW's that you should consider replacing the water pump and thermostat.
And usually at around 90K the radiator and cooling hoses and coolant. Anti-Freeze (coolant) should be replaced every five years bc as it ages it gets more acidic. The PH level goes up(& up) and it eats the cooling system from the inside out as time goes by. Also one should use the proper BMW coolant as its different from say Prestone or what ever your local store sells.
      02-27-2013, 10:18 AM   #71
takrdown
Other car was a submarine
takrdown's Avatar
94
Drives: i4M50 (waiting), 2013 R56 JCW
I'm officially freaked out and I'm going to be ordering both in the late Spring. I might as well give adjusting my front wastegate a shot while I'm in there. My mileage is at 113K.
Dack....if the PH is going up...wouldn't it be getting more basic not acidic
      02-27-2013, 10:27 AM   #72
Dackelone
European Editor
Dackelone's Avatar
Germany
10607
Drives: N54 e82
113K miles ? Yea... I would order a pump and thermostat ASAP.
Yea... your right. I did not mean that "up" figuratively. But the coolant does get more acidic was time goes on. Also the coolant loses its ability to stop corrosion.
      02-27-2013, 08:57 PM   #73
yawn
+1
DIY Water Pump & Thermostadt Replacement (2007, 335i w/Automatic Transmision)
Thanks Dack!
      03-11-2013, 11:29 PM   #74
spellbmw
Feuertrunken
spellbmw's Avatar
Drives: MY10 135i 6MT
I should probably make a post and say my waterpump is still the original one.
I have a 2010 MY, 135i with 56K miles. N54 engine.
+1
Crimson-Coral Red |Walnut | iDrive | Premium & M Sport | Heated seats | PDC |CA | Premium hi-fi | BMW SSK & PE | BSH OCC -
Deposit 7/15/2009 - Ordered 9/18 - Production 9/23-30 - Euro Delivery 10/17 - Shipped 11/13 - Oxnard 12/8, Oregon 12/24 & home on 12/30
      03-13-2013, 12:35 PM   #75
InlineSix
TwinTurbo Top Hat
Drives: 2016 M235i
Water pump leaking, and oil filter housing leaking oil as well... Warranty just expired Jan :-/
46K Miles - 2008
AW 2008 135i - Auto, Prem, with Sat Radio
BMW CCA # 417107
      03-14-2013, 04:31 PM   #76
Lucky1
Drives: '08 128i Coupe SGM 6MT
I'm still covered under the CPO warranty so I think I will take my chances and wait to see if my pump fails on me before CPO ends.
      03-14-2013, 08:21 PM   #77
rking117
Drives: Z4 3.0i & 320i
I dont think this covers enough models that have the same engines / water pumps. I had an E85 Z4 that lost it mind when the water pump failed. I had to have it towed not doubt to the dealer to have it replaced. Same engine water pump.
Year 06
Model Z4 3.0i roadster
N52
around 65K = fail
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold)
      03-26-2013, 01:50 PM   #78
kits135i
Drives: Coming Soon
19k on the nose and it failed for me...
      03-28-2013, 04:42 PM   #79
n54oner
Drives: '09 135i
I have an 09 135i that just hit 50k miles and I'm still on the original pump. But, about 1.5k miles ago the coolant light came on and that got me worried. I filled it back up that same day and the level is still good to date, but I'm wondering if that was a sign of issues to come, or if it was just low for some reason. I assume a dealership won't replace it just because it 'might' fail, before my warranty runs out, huh?
      03-30-2013, 10:06 AM   #80
IDBMW
IDBMW's Avatar
Drives: 2019 X3 M40i
I wish I could change my vote. My water pump died a couple of weeks after I posted all was well!
Model Year/Production date__2008 / May 2008_____Miles__52K______Warranty/Good Will ? Extended warrranty______Engine Code__ N54
2019 X3 M40i - Black Sapphire Metallic - Mocha Lather - 21" 718M wheels - Every option except Sun Shade
      04-03-2013, 05:06 PM   #81
WSUone
Drives: 08 135
MY 2008, built 03 2008 51700 Miles. N54, cost 1238 no warranty.
This turned out to be an interesting ordeal.
1. Water Pump Fails
2. Replaced by Wichita BMW
3. Driving home the Oil Temperature gage goes to 250 after 5 minuts of driving and the oil level indicator says inactive. The Oil Temperature gage dropped down to 200 in about 2 seconds as I was watching it, and then the Oil level gage showed the right amount of oil. No indication of anything wrong.
4. Got home parked the car came back out after an hour and had coolant all over the garage floor.
5. Tow truck came the next morning and the battery was dead. Had to push the car out of the garage.
6. BMW replaced the water pump the next day and said that apparently the first water pump replacement shorted internally as I was driving down the road causing the bizzare gauge malfunctions and drained the battery overnight.
7. Alls well that ends well, but just be aware that if the pump dies it can cause some strange things to happen.
These cars will cause you to fret, and I was cursing it for a while but in the end they are too much fun to give up.
      04-05-2013, 04:23 PM   #82
Dackelone
European Editor
Dackelone's Avatar
Germany
10607
Drives: N54 e82
26 waterpump failures out of 192. Not looking good. This just goes to show us that the waterpumps need to be replaced.
      04-05-2013, 04:40 PM   #83
Colt
Spoolin' & droolin'
Colt's Avatar
Drives: 08 135i 6MT
I'm almost at 40k....might just replace it soon before it happens
Originally Posted by Nate4641 View Post
looks like unicorn vomit.
      04-05-2013, 06:55 PM   #84
Maranello455
Maranello455's Avatar
Puerto Rico
34
Drives: 09'M-3,99'M3,02'M-3,88'M6,74'T
Also need to change my vote. The WP in my 2009 135i failed. Water Pump Kit replaced by dealer under warranty at 14K miles.
2009 N54 335i Sport
      04-05-2013, 07:12 PM   #85
bozola
Unloved BMW Addict
bozola's Avatar
Drives: Z3 Coupe, 3 318Ti
1999 Z3 Coupe  [10.00]
1998 318Ti  [0.00]
1998 318Ti  [10.00]
2008 128i  [9.00]
I wonder if there is a statistical difference between the 128 and the 135's
      04-12-2013, 12:51 PM   #86
bluesunit
Drives: D-Stock 135i
Spoke too soon . . .
No lie, I answered this poll two weeks ago and my water pump grenaded.
53,000 miles
Covered under extended warranty. Since my warranty expired, I've had seat airbag issues $$$ and the water pump go out . . . Smart purchase decision!
      04-12-2013, 01:01 PM   #87
ChristianReyess
Drives: 135i
Model Year/Production date 2008 Miles 50k Warranty/Good Will ? CPO warranty Engine Code N54.
Happened 2012 / oct
      04-14-2013, 05:49 PM   #88
RnmEvo9
Drives: 2007 335i
My waterpump went at around 62500 miles on my 2008 135i. It was covered under CPO warranty.
1addicts
