02-24-2024, 08:54 PM | #1 |
Rep 3,875
Drives: 330i, 135i
Passive Go Module Replacement
Has someone replaced their CAS module in their 1er? I brlieve its on the right side behind wheel liner. I may have to replace it since if I want keyless function working again. I tested the fuses and all are working. I would like to inspect it for any water access too ans part #. I drove my e88 in the rain a couple if days since my e90 was in the shop for water pump replacement 🥹. I brlieve started to have the keyfob issues after the rains. 😕
02-25-2024, 10:46 AM | #2 | |
BMW Owner Since 1971
2267
Rep 1,415
Drives: 1964 700 Sport Cabriolet
cerealwars79.50 |
02-25-2024, 11:19 AM | #3 | |
Rep 3,875
Drives: 330i, 135i
How hard is it to gain access to it? I believe you have to remove the wheel liner cover and trunk plastic trim correct? I ve trying to find something online but not much luck so far. |
02-25-2024, 05:07 PM | #4 | |
Rep 3,875
Drives: 330i, 135i
02-25-2024, 06:00 PM | #5 |
Rep 3,875
Drives: 330i, 135i
I forgotto mention. In my case most likely the water is coming in from the right side tail light. I had an issue with the blackline tail light replacmenet I got when the insise screw base got stripped and couldn’t tighten the tail light screws ever since. Meaning its set loose. Therefore water comes in. Even when I wash the car?
Now I know I wont be driving my E88 in the rain until I fix or replace that stupid tail light. 😠 |
cerealwars79.50 |
03-31-2024, 06:42 PM | #6 | |
Rep 2,051
GoRomeo980.00 cerealwars79.50 |
03-31-2024, 09:55 PM | #7 |
Rep 3,875
Drives: 330i, 135i
My passive go module works great with all but I noticed it may have glitch. When the passenger door opens sometimes I get an error message on the screen saying “Key is not detected” even though I have the key with me sitting on the diver side. Engine running. Anyone else hasor had this issue? Mine could be from the last time it got wet? 🤔
04-02-2024, 05:59 PM | #8 |
Rep 1,979
Drives: '13 128i, '23 iX M60
I had to replace mine. No crashes and original taillight. I think there’s another design defect allowing water in.
I added some tape to block off part of the vent that’s in there, thinking there may be some backsplash when driving in the rain. I also don’t drive it in the rain any more. Here’s hoping the new module stays dry!
2023 BMW iX M60 BSM
2013 BMW 128i 6MT MGM/CR. M-sport/Premium/Cold, HK, Xenons, BMW SSK and PE. ED 7-12-2013 SOLD: '07 E90 6MT BSM/Terra, '18 F31 Sunset/Oyster, '21 Polestar 2 http://www.1addicts.com/forums/showthread.php?t=897862 |
04-02-2024, 06:09 PM | #9 | |
Rep 3,875
Drives: 330i, 135i
04-02-2024, 07:55 PM | #10 | |
Rep 1,979
But I have no broken/replaced taillight. But who knows. Regardless, it’s a shitty design for BMW to put the electrical module at the bottom of a well with no way to drain
2023 BMW iX M60 BSM
04-02-2024, 07:57 PM | #11 | |
Rep 3,875
Drives: 330i, 135i
LuisBoston564.00 |
04-23-2024, 02:35 PM | #12 |
Rep 299
Drives: 2010 128i ZSP 6MT
Just did it a couple of months ago. Took me all of 20 minutes to remove the trunk liner, install, and reassemble everything. Worked like a charm.
I'm not sure how warm the module gets (which would really be my only concern), but I wonder if sealing the whole thing in some of that rubber dip you use for screwdriver handles would help keep it dry inside?
2010 128i ZSP 6MT Coupe
Deep Sea Blue (Tiefseeblau) Metallic Style 264 Wheels Lemon Boston Sport Interior |
cerealwars79.50 |
04-23-2024, 03:21 PM | #13 | |
Rep 3,875
Drives: 330i, 135i
☝️☺️ In sure the ventilation helps cooling the module. Not sure how warm it can get. Im more concert about the moisture going inside. |
Donkeyshins377.00 |
04-23-2024, 08:36 PM | #14 |
Rep 1,979
An update from me:
The comfort access on the driver door now stopped working. I checked a fuse and it was fine. I also checked the new passive go module in the trunk and it’s dry as a bone in there. Now trying to find a drivers side door handle with Ca, but am told they are out of stock and unsure they’ll be available again. Perhaps BMW has stopped supplying them 🤷
2023 BMW iX M60 BSM
04-23-2024, 09:07 PM | #15 | |
Rep 3,875
Drives: 330i, 135i
04-23-2024, 09:17 PM | #16 |
Rep 1,979
Perhaps. It’s been installed for a year.
2023 BMW iX M60 BSM
04-23-2024, 09:24 PM | #17 |
Rep 3,875
Drives: 330i, 135i
LuisBoston564.00 |
04-23-2024, 09:28 PM | #18 | |
Rep 1,979
Just one on eBay and it’s the wrong color. Thinking I could get it to at least test it. Then if it works, put my grey one back and wait for supply.
2023 BMW iX M60 BSM
GoRomeo980.00 |
04-23-2024, 09:34 PM | #19 |
Rep 3,875
Drives: 330i, 135i
04-23-2024, 10:57 PM | #20 | |
Rep 299
GoRomeo980.00 |
04-24-2024, 12:57 AM | #21 |
Rep 3,875
Drives: 330i, 135i
One more thing I noticed on this tricky Moduleat times is that when I dont drive the car much and battery is not being fully charging by alternator , it starts to kick that error message about “key not detected “ when its in my pocket. Not sure if this is due to my module gotten wet at some point or is this another “low charge” gremlin like in all BMWs. I don’t remember doing this before it got wet though. 🤔
Whenever the car is driven continuesly I don’t get this message l. |
04-24-2024, 05:54 AM | #22 | |
Rep 1,979
2023 BMW iX M60 BSM
GoRomeo980.00 |
