      03-01-2011, 01:23 AM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
>>> HP Autowerks <<< aFe Stage 2 N54 Intake
Producing 14 max horsepower and 27 lbs. x ft. torque, this radically different Stage 2 sealed cold air intake system is engineered to let maximum air in while keeping engine heat out.this intake system smoothly directs increased air flow for improved volumetric efficiency and maximum performance. So effective is the design that Intake Air Temperature (IAT) at normal running speeds with this aFe intake system is 11 degrees lower than the factory intake. Easily accessible with a satin black powdercoated aluminum cover, an washable/reusable conical air filter is enclosed in a molded plastic housing and mounted on a oval intake tube that smoothly supplies maximum air to the twin turbos. The full effect of this system cannot be felt or tested on stationary dyno and can only be fully appreciated on the wide open highway.
We've decided to sweeten the pot even more!
If you place your order with us, we will not only provide you with the discount on the aFe stg 2 intake with FREE SHIPPING, but we will also offer you one of the following:
2 FREE Bottles of Motul 600 Brake Fluid
10% off of Macht Schnell DP
20% off of Macht Schnell Air Scoops
20% off of HP Autowerks Adjustable Endlinks
>>>>>>>>> Order Here: http://www.hpashop.com/product.sc?pr...categoryId=110
with FREE SHIPPING! Spoke with aFe and they are not in stock with NO eta of when they will ship.
      03-03-2011, 09:53 AM   #2
NYAWE60
NYAWE60's Avatar
660
Drives: 2008 Porsche 911 Turbo 6 speed
With the sealed top, I think it'd be naturally more efficient than the other open dual cone intake that AFE produces. I'd like to see independent dyno testing. With a 14 hp and 27 lb-ft torque gain, the $500 asking price may be justified.
      03-03-2011, 11:13 AM   #3
HP Autosport
Drives: F80 M3
      05-05-2011, 06:32 PM   #4
HP Autosport
Drives: F80 M3
In stock now!
      06-09-2011, 08:51 AM   #5
NIGnBMW
NIGnBMW's Avatar
Drives: 2007 E60, Black Sapphire
Do you guys manufacture intakes for the N52B30 Engine also?
3-Stage Intake Manifold mod & Active Autowerke ECU re-map for 40+ HP Gain and 35ft-Lbs torque!, RPI GT Axle-back Exhaust System, Sprint Booster V2, RPI Scoop & BMC Filter, Carbon filter delete.
