07-30-2024, 05:58 PM | #1 |
Rep 263
Quiet Pressure Washer for Detailing?
So after years of washing my car in a coin op (All using my own brushes/microfibers/chemicals), I am finally moving into a townhome with a garage that I plan to wash my car in. Because its a pretty tightly spaced building with two adjacent units and a couple units within ~50 ft, I have concerns with the noise from getting a pressure washer, and even more so the Ego blower that I regularly use. (Not to mention the exhaust)
I want to keep the whole budget (after new guns, fittings) at around $600, so my top pick was the Active 2.0. However, with my townhome situation, I am worried the noise will be a bit too much. Then came the new Ego Pressure washer. From various internet sources it looks like the Ego is at around 67 db, Active 2.0 at around 80. I would have to get the Ego's whole battery kit at $800, but the Ego stock gun and fittings look like something I get get by with (maybe swap out later). I know Active will perform better at a fraction of the cost, but maybe the quiet Ego might be worth it? Anyone with similar use cases? Any other ways to insulate the Active 2.0?
2021 BMW M2C / AA / Remus / KW / Eventuri / Autosolutions
07-30-2024, 06:55 PM | #2 |
Rep 52
Drives: 2010 E92 M3 DCT - Space Grey
I have the Active 2.0. I'm not in a townhome situation so the noise is not of a great concern, but I don't find it overly loud. The big thing that I noticed when I got it was by switching to electric from gas the noise isn't constant. I think that helps a lot when you are concerned about the noise. Mine stays on the bottom shelf of a Harbor Freight metal cart.
07-30-2024, 07:06 PM | #3 |
Rep 1,194
For $800, you might as well spend a, "little" more and get a Krazle.
Active 2.0 or Karcher 1700 are probably the move. I went with a 2GPM Greenworks and regret it due to the ramp up pressure but that's supposed to preserve the motor. Got a good discount with 3 year warranty but man the 3 sec ramp up kills me. |
07-31-2024, 06:25 AM | #5 |
Rep 387
Why wash your car in the garage? Too confined IMO. If you don't have HOA restrictions I'd wash it outside with the pressure washer either in the garage or a room adjacent to the garage. I have zero noise concerns, but this is what I did as I didnt want my pressure washer in the garage due to possible freezing in the winter months here in the North East. My pressure washer is mounted to a cart with a 75' hose on a hose reel. I run the hose through the basement-to-garage door, through the garage bay out to the driveway. If I really want to reduce the noice I can also close the garage door, but I don't find it nesessary. Buy the 2.0 and good luck!
07-31-2024, 11:47 AM | #6 |
Rep 263
Sorry I meant in garage as in garage+driveway, but given the 3-story layout of the townhouse, the only adjacent room is the front door.
I did look at the Karcher K1700 cube as well because they were so damn cheap, but you can tell even in just the videos the GPM is noticeably lower than Active, plus it doesnt sound any quieter. Any thoughts on putting the pressure washer inside a custom sound insulated box? I'd have to cut out holes for power and hoses but thought it might help? Probably overthinking all this but just nice to have some ideas ready!
07-31-2024, 01:35 PM | #7 |
Great Teacher
1561
Rep 1,473
Drives: 06 e91 325ix
Run an extension hose for the nozzle and leave the pressure washer in the garage itself. If you feel it is too loud (it isn’t) then close the garage door behind you.
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
Bruuuce365.50 |
07-31-2024, 05:34 PM | #8 | |
Rep 387
Add four sides to this and you're done. Enclosed and mobile! https://www.amazon.com/WEN-73009-500...26&sr=8-7&th=1 |
07-31-2024, 06:45 PM | #9 | |
Rep 1,194
arsunic49.50 |
07-31-2024, 08:45 PM | #10 |
Rep 43
Also live in a townhouse and have a full pressure washer setup with the active 2.0.
I generally shut the garage door with plenty of slack on the hose and that makes it significantly quieter. But even when I don't, I haven't had any neighbors complain about the noise. As long as you're not washing super early in the morning or crazy late at night, I don't imagine you'll get any complaints. Realistically, I'm probably only running the pressure washer for 15 minutes during a wash(rinse, foam, rinse, foam, contact wash, rinse). I love the active 2.0, but the new EGO batter pressure washer seems pretty awesome so I don't think you can go wrong here. I think if you value the mobility and plan to use your unit for other things around the house, the EGO is your best bet. For overall value though the Active 2.0 is the best unit you can buy. |
Bruuuce365.50 |
08-01-2024, 12:28 AM | #11 | |
Rep 263
08-01-2024, 06:11 AM | #12 |
Rep 10
I bought the Chemical Guys pressure washer recently - to me, it is quiet. I had it sitting just outside my garage. I've used it elsewhere to help clean a cargo trailer with very good results.
https://www.chemicalguys.com/product...ressure-washer I also bought their foam cannon - they have a sale for it and the snubby handle - the washer comes with the longer handle. https://www.chemicalguys.com/product...ng-starter-kit Yes, I know - some will consider it a "starter or amateur" system, but I think it will work well for me for quite some time. |
Nyyrule96.50 |
08-01-2024, 10:08 AM | #13 | |
Rep 43
I've asked that neighbor if the noise is a problem and they say they don't really notice it - so yea you won't really know until you try. But seriously yea this was my biggest concern, I didn't want to be that neighbor with the noisy pressure washer! I probably do a full pressure washer wash once a month and do a rinse less wash every week. |
08-02-2024, 01:56 PM | #14 | |
Rep 12
