08-22-2024, 09:56 PM | #1 |
Rep 22
N20 equipped vehicles recalled for water pump fires
N20 engine has excessive blowby (that's why I have an oil catch can installed) which can leak out onto the electrical connector for the pump, causing short circuit and possibly resulting in a fire. I read that up to 2016 328i and drives are affected, but my 2016 has the updated (remember the timing chain guide defect?) N26, so is it a recall or is it not?
11-03-2024, 08:06 PM | #2 |
Rep 1
It's likely, both the n20 and n26 had the recall. If you go to a BMW dealer you could likely get it done, or call your local dealer with your vin and you should get an answer.
11-04-2024, 11:06 PM | #3 |
Rep 2
It's possible that the recall was issued for both the N20 and the N26. You might be able to get it done if you travel to a BMW dealer, or you could call your local dealer with your vehicle identification number and you should get an answer out of them.
