06-29-2024, 11:57 AM | #1 |
Rep 1,764
I get a 403 Forbidden to access error
Right now, I get a 403 Forbidden to access error on both my PC and my cell phone on the same wifi. I had to switch to another IP address via VPN to be able to see/access the Bimmerpost site. I am not "banned", so what could be the issue?
In the past two months there have been numerous site outages at random times, not just at the 2am EDT site backup/updates.
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
06-29-2024, 02:28 PM | #2 |
Rep 1,764
I tested on my cell phone on 5G/LTE cell data on the road and I can access. At home using my wifi I cannot access the forum, I get 403 Forbiden error. Can you check please?
When I change to the different IP address on the same wifi network using VPN, then I can access again. I tried a different browser Firefox (and Chrome) and both. So my IP Address is blocked by Bimmerpost.
06-29-2024, 02:42 PM | #3 |
Rep 1,764
My IP Address is blocked by Bimmerpost. I used two different browsers Chrome and Firefox, and the same 403 Forbidden. I also released my IP address and renewed it.
I am only able to type this using VPN.
06-29-2024, 04:23 PM | #4 |
Rep 1,764
I can now access again Bimmerpost using my normal wifi IP address. Thank you.
apptest droid756.00 apptest4590.00 |
07-03-2024, 09:02 AM | #5 | |
Rep 74
Thanks so much! |
07-03-2024, 06:20 PM | #6 |
Rep 1,764
I didn’t resolve it on my end. Something that Bimmerpost did to fix it. I don’t know if there was an error during their updates, or somebody accidentally added me to the blocked list?
07-03-2024, 06:59 PM | #7 | |
Rep 74
Turns out something similar happened on my end. I wrote the the hosts and after explaining the situation in now no longer get the 403 Forbidden error. All good now. |
fe7565619.50 |
07-03-2024, 09:24 PM | #8 |
Rep 50
07-03-2024, 11:23 PM | #9 |
Rep 74
07-06-2024, 08:27 AM | #11 |
Rep 1,899
07-06-2024, 12:23 PM | #13 |
all I do is test!
4590
Rep 998
Drives: I lost count of how many
If really for a few weeks then it makes you wonder if your work is blocking it
Test 23456rt
07-06-2024, 01:58 PM | #14 | |
Rep 6,375
What happens is that the page just doesn't load, I get the web browser error page that can't reach/load the website, I can't remember the exact error code I'd have to check at work again and report back. |
07-06-2024, 02:00 PM | #15 | |
all I do is test!
4590
Rep 998
Test 23456rt
07-10-2024, 09:18 PM | #16 |
Rep 8
07-10-2024, 09:27 PM | #17 |
Rep 8
07-10-2024, 09:31 PM | #18 |
Rep 8
I just checked the website and I get the same thing. It will load the pm but as soon as it comes up it turns blurry to where I can't make out any words. This is new as 2 days ago I could send pms and read them no problem.
07-10-2024, 11:59 PM | #19 | |
all I do is test!
4590
Rep 998
Thanks! 👍
Test 23456rt
07-11-2024, 01:21 AM | #20 |
Rep 8
If you still need it, I did a screen recorder of everything I mentioned. It also says no connection even though I'm logged in and I def have internet connectivity. I'm going to toggle wifi on and off to see if that changes anything. Thanks for the help!
apptest4590.00 |
07-11-2024, 07:47 AM | #21 |
all I do is test!
4590
Rep 998
Let’s try the new version and see if it also helps with the connection issue. The two might be related. It usually takes only 1-2 days for an app update to get approval so hopefully it will be soon 👍
Test 23456rt
M850i BSM3.00 |
07-13-2024, 06:47 AM | #22 |
all I do is test!
4590
Rep 998
Ok the new version is now available on the App Store which I believe fixes your problem 👍
Test 23456rt
