12-03-2019, 12:04 PM | #133 |
Rep 6,289
Anyone noticed higher temps with Pennzoil vs Castrol. I'm not sure if I'm just not recalling correctly but I feel like it sits higher in hot outside temps and sits colder in winter temps.
12-08-2019, 09:41 AM | #134 | |
Rep 3,726
If I was running long oci, I'd use Motul Xcess since it has a similar formulation as Castrol but more additives PPM.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
12-11-2019, 08:43 AM | #135 |
Rep 2,174
I have done so many used oil analyses and have looked at thousands more on bitog.com. Results:" oil is oil" . No difference between Wal-Mart supertech and Motul oil as far as results. Use a syn for extended drain intervals. I persolnally use QS Ultimate Durability. But then again I drive Subarus
More important is the filtere. Fram Ultra Synthetic Imho the best. Filters a t 20 microns vs most filters which are 30 to 40 Last edited by adc100; 12-11-2019 at 08:50 AM.. |
floydarogers690.00 |
12-13-2019, 01:39 AM | #136 |
Rep 3,726
Heads up: Since Castrol Edge 0w-40 is no longer LL-01 approved, Castrol's website is now recommending their Castrol Edge 5w-40 weight as being LL-01 approved.
See MSDS/product detail: https://msdspds.castrol.com/bpglis/F...582A4004AD6DA/$File/BPXE-AA5D4U.pdf Looks like this one can be found at Walmart for $25. Sounds like I'll be running this version going forward since Pennzoil Platinum 5w-40 is hard to find here.
12-13-2019, 09:26 AM | #138 |
Rep 2,362
Drives: G87 M2; E92M3 MT&DCT; M3 euro
10w-60, an adequate grade for a real racing engine.
Pass me if you can.
12-13-2019, 08:04 PM | #139 |
Rep 70
Drives: 2011 BMW X3 35i
Total Quartz Energy 5W40
12-24-2019, 02:08 PM | #143 |
Rep 117
Castrol Edge Titanium 5W30 M (previously C3) in my E61 525d (Netherlands).
I've tried one time Shell Helix 5W30 but I noticed the engine wasn't as stable and quiet as with Castrol. Also the turbo was slightly more noticeable. So for me never something else besides Castrol. Oil change every 25k-30k kms. I only drive long distances (highway). |
12-26-2019, 03:59 PM | #144 |
Rep 2,174
After doing many UOA analysis and viewing thousands more on bitog.com. Oil is Oil little if any difference in wear metals.
I think though that QS Ultimate is one of the best. That's what I run. But also the filter is more important. Fram Ultra Syntetic is the best. filters at 20 microns vs 30+ microns for others (including BMW). Will cut your wear in half. https://www.machinerylubrication.com...ose-oil-filter |
12-30-2019, 11:30 PM | #145 |
Rep 367
In theory, would a 0w30 allow you to drive aggressively sooner than a 5w40?
i.e. generally people recommend ~180f oil before pushing it. How different is that for 5w40 vs 0w30 (obviously keeping all else constant) |
12-31-2019, 01:59 PM | #147 |
YNWA
1043
Rep 813
5w30 for N52
10w60 for S54 Prefer Castrol, but any high quality full synth will do.
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 |
01-02-2020, 06:30 AM | #148 | |
Rep 18,733
01-02-2020, 06:35 AM | #149 |
Rep 6,289
01-02-2020, 09:24 AM | #150 | |
Rep 10,351
https://wiki.anton-paar.com/us-en/engine-oil/
"Drive more, worry less. "
01-02-2020, 10:52 PM | #152 | |
Rep 367
01-16-2020, 05:36 PM | #153 |
Rep 2
I have the M6 with the S63 engine. Was on the west coast with just dealer changes and top offs. Now am in PA with one dealership..and not a good one. Switched to Mobile 1 5W30 but didn’t trust the filter they used. Got a coupon from the dealer and they changed to OEM 5w30 but I bought some Redline Euro formula 5w30 to top and am seriously considering changing my own oil and using the Redline. I have been hearing about Motul, Rivera, Schaffers, Lucas, Amsoil and some others. No one is really discussing them, all premium expensive oils. Okay, so perhaps at that level they are all the same. It is winter here and temps get pretty low. I warm my girl up but I’m always wondering how best to treat her. So would love any advice of what viscosity I should really be using? FYI-she has 51k on her (2013) but BMW dropped a new engine in her 17k ago. So my decisions on maintenance have to bear that in mind. Would love to hear all your thoughts.
01-24-2020, 07:36 PM | #154 |
Rep 706
2020 M240IX
1st Oil Change, just under 1k miles, Moly Leichtlauf High Tech Engine Oil 5w40, Mann Filter. Engine sounds smoother, was surprised at how dirty the oil was already. Is a nicely thicker oil. Sending it to Blackstone, just for the hell of it, benchmark at least. |
