ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > Classifieds > Sponsors Classifieds > Suspension / Brakes / Chassis / Spacers
      04-19-2024, 10:54 AM   #1
IND-Distribution
BimmerPost Supporting Vendor
IND-Distribution's Avatar
9604
Drives: G82 M4 / G87 M2
IND | Fall-Line Motorsports F8X Adjustable Sway Bar Links - Pinch-Nut Fasteners
MADE IN THE USA
Lowering your car is often the first step in suspension tuning, but occasionally, this process can adversely affect other associated components. Unwanted sway bar pre-load may be one of these consequential effects, adding asymmetrical spring rate bias to one side of the car versus the other. This imbalance may affect your overall chassis dynamics and corner balance.
For this reason, adjustable sway bar end links are critical—by adjusting each link with the car at operating weight, you can ensure the sway bar is completely unloaded at your determined ride height, restoring your chassis' balance and your confidence in all driving situations.
Unlike all other link kits on the market that utilize the cheaper and simpler jam-nuts, Fall-Line's new V2 utilizes OE tie-rod end style pinch-nut fasteners to ensure they never lose their set length.
V2 Key Features:
  • Now includes OE tie-rod end style pinch-nut fastener rod ends
    • Eliminates the typical jam-nut rod ends that are known to move over time
  • Designed for superior corner balancing
  • Ensures equal weight distribution on each tire
  • Compatible with height adjustable dampers
  • Eliminates uneven cross-weights
  • Prevents sway bar-induced suspension stress
  • Allows for precise customization through length variation
  • Includes dust boots to protect against dust interference
  • Made in USA
  • Sold as a pair
The Fall-Line Motorsports F8X M2 / M3 / M4 Adjustable Sway Bar Links - V2 may be viewed at the following link to our online store:
Front: https://ind-distribution.com/product...r-end-link-kit
Rear: https://ind-distribution.com/product...r-end-link-kit
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
f80post
