05-29-2020, 01:32 PM | #1 |
Rep 2,350
ZF 8AT Transmission Fluid Questions
My E84 xDrive28i is at the 95.000 km mark and I would like to change the fluid. BMW sells a kit, however the transmission fluid in it is BMW brand, not the OEM ZF Lifeguard. I know that the transmission is extremely particular about the fluid.
Thank you kindly! |
05-30-2020, 12:39 AM | #2 |
Rep 681
I bought the zf fluid as part of a kit from fcpeuro. But there's also a liquimoly alternative which some users on the f3x forum have found to work just fine as well.
BMW's fluid is likely just rebranded ZF fluid fwiw. I also don't think the zf8 is all that picky about fluid as long as you don't go down the "lifetime" fluild route.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
Teutonic2709.00 |
05-30-2020, 10:55 PM | #4 |
Thaumaturge
181
Rep 211
Me too. The kit was wonderful, a good price and comes with a lifetime warranty. I will never use the warranty but that doesn't mean others can't.
If you do it yourself be sure to follow the procedures to the letter to be sure you get all the fluid out and the right amount back in. There are some good videos too with the full procedure. It's not a simple drain and replace. ///Rich |
Teutonic2709.00 |
05-31-2020, 05:08 PM | #6 | ||
Rep 2,350
First of all thank you for all your replies. I am however in limbo as the information I am gathering is kind of confusing. This is the reply from ZF USA: Thanks for contacting ZF in regards to your X1. The ZF fluid would be the Lifeguard Fluid 6 or BMW Oil No. 8322 0142516 which is used in all ZF equipped BMW's with 6HP transmissions. The FCP Euro kit is cheaper than the dealer and honestly I will go for it just to be sure I have the OEM oil. The problem is however that: - The ZF is saying that my AT is a 6HP and suggests fluid 6. - The kit suggested by the FCP Euro says 8HP https://www.fcpeuro.com/products/bmw...-24118612901kt My transmission is a 8 AT ZF, Should I presume that the code 8 refers to the 8 speed? Also, is the kit missing the filter? Thank you |
05-31-2020, 05:53 PM | #8 |
Rep 2,350
06-01-2020, 04:42 PM | #9 | |
Rep 10,351
The 8 denotes 8-speed. ZF8HP, 6HP, 5HP, etc If you're not certain as to whether you have a 6 or 8 sp you can look at the documentation which came with your vehicle or run a VIN decoder.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
06-01-2020, 05:52 PM | #10 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
Redline D6 for 8HP, that or D4 for the 6HP.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
06-19-2020, 04:06 PM | #11 |
Rep 1,343
Since you're in Canada, you can check out Canadian Tire. They have a new line called OEM brand. One of them is European MV LV transmission oil. It listed ZF 6-8 speed/vitesses compatibility.
The maker for this brand is Rechochem IIRC. |
06-21-2020, 11:33 PM | #12 | |
Rep 2,350
Thank you for the reply. |
