09-09-2019, 05:58 PM | #793 |
Rep 145
I have a feeling that this is because the car was designed in the z06 configuration and then they started removing things to make the bargain car. Wait until the higher performance trims come out and we'll see how everything comes together then.
09-11-2019, 01:33 PM | #794 | |
Midlife Crises Racing Silent but Deadly Class
1817
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
09-11-2019, 03:16 PM | #795 |
Rep 1,011
09-11-2019, 03:51 PM | #796 | |
1817
Rep 5,337
You can clearly see the centerline of the transmission and it's input shaft sits ABOVE the flanges of the half shafts of the diff on the transaxle. Unlike the C7 transaxle where the diff sits behind the transmission, the entire center line is lined up with the center of the flywheel. So ANYONE intimating that the LT2 sits lower in a car than the LT1 is, yes... LYING. If your source that says the LT2 sits lower than the LT1 is the chief engineer of the Corvette, Tadge Juechter, then that's an unequivocal YES. Not that he "lies," but you have to read between the lines in everything he says, because he's an active spokesperson for the Corvette program and frankly, parses everything he says. If you're active on the Corvette Forum, he actually has a "Ask Tadge" forum and while he did not have to participate, he does, and the more you read the more you realize that everything he says to the public is designed to be said to the public, and most of the time certain detail is omitted in the way he phrases it so that there's enough ambiguity that you can't call him out for an out-right lie. A statement such as "the new LT2 in the C8 has a lower center of gravity than the LT1" has a crucial detail omitted. Which LT1 in which car. If you don't do your own research, and understand how things work, you can easily read that to imply the LT2 sits lower than the LT1 IN THE CORVETTE C7. But that's not what he said. The LT2 sits lower than the LT1. Without implication, that can mean the LT2 sits lower than all LT1, or sits lower than the LT1 in the CAMARO. Which it does. Based on the information I've provided, the fact that the dry-sump equipped LT1 in the C7 sits on the same plane as the transaxle and has the exhaust manifolds yield DOWN rather than up, do you REALLY think that the LT2 in the C8 sits much lower than the LT1 in the C7? And if you do, is that purely based on TJ's saying that it does, without implying that it's the LT1 in the C7? Because the CENTERLINE of the output half shafts on the C8 already sits 1" higher than the centerline of the output half shafts on the C7 (the rear tires are 2" taller in diameter in the C8), and the flywheel on the LT2 in the C8 would sit another 2" higher than that based on the diagram of the DCT transaxle. So you tell me how it is possible that the LT2, which has basically the same block, but one more cam shaft, and an exhaust that routes UP instead of down, has a lower center of gravity than the LT1 as equipped in the C7. The ONLY thing I will concede, is I've actually never read where TJ or any of the engineers imply that the LT2 in the C8 has 2" lower center of gravity than the LT1 in the C7. I don't know if the statement is as cut and dry as "LT2 sits 2" lower than the LT1" or if they implied that the actual center of gravity in the C8 is lower by a couple of inches over the C7 (entirely possible as a package). All I know is it's highly unlikely that the actual LT2's center of gravity as mounted in the C8 is actually several inches LOWER than the LT1's center of gravity as mounted in the C7. If you use the main crank pulley as where the centerline of the crank shaft is, and by relation where it mates and mounts up to the DCT transaxles are, by comparison the LT2 can't POSSIBLY mount lower on the C8 chassis than the LT1 in the C7. LT2: LT1:
SYT_Shadow11421.00 eluded2959.00 |
09-11-2019, 06:42 PM | #799 |
BMW Fan
449
Rep 725
Corvette owners are the absolute WORST anytime a new generation drops. The C8 is no exception.
It will most likely be superior in any comparable way, outside of having a manual transmission and being able to put a dog in the cargo area, to a comparable C7. Suggesting that GM engineers are lying about the car, which easily reasonable given the layout of the new chassis is ridiculous. |
09-12-2019, 04:16 AM | #800 | |
Rep 2,250
I know because even I'm guilty.
09-12-2019, 06:11 AM | #801 | |
Emperor
1611
Rep 2,753
The claim is not the engine itself has a lower center of gravity. The claim is that the engine is able to be mounted lower (because of the standard dry sump), creating a lower center of gravity in the car.
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport |
See5449.00 OkieSnuffBox1802.50 |
09-12-2019, 08:58 AM | #802 | |
BMW Fan
449
Rep 725
09-12-2019, 11:05 AM | #803 |
Rep 407
Drives: Miss Daisy
09-15-2019, 12:23 AM | #804 |
Rep 1,087
09-15-2019, 12:10 PM | #805 |
Rep 1,916
I won’t be buying a 2020 Z51 but I very well might jump on this.....
https://www.topspeed.com/cars/chevro...-ar186406.html
"The Constitution was never construed to authorize Congress to infringe the just liberty of the press, or the rights of conscience; or to prevent the people of the United States, who are peaceable citizens, from keeping their own arms.” Samuel Adams |
09-15-2019, 12:32 PM | #806 |
Primo Generalissimo
4546
Rep 3,995
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [7.75] |
I’m happy with my 2LT Stingray. The 2LT C8 is a nice upgrade over it. I don’t think I need a Z06 to make me happy.
09-15-2019, 12:56 PM | #807 |
Rep 1,916
My current C6 makes more then the C8 Z51 does, it’s hard to go backwards.
09-15-2019, 01:12 PM | #808 |
Primo Generalissimo
4546
Rep 3,995
Drives: All of them
N54Yankee2706.00 |
09-16-2019, 09:45 AM | #809 | |
Rep 407
Drives: Miss Daisy
I've owned a bolt-on C6 Z51, a modded C6Z & a 600+ WHP C5. If I get another Vette, it has to be a C7 or C8. (Would love a 67 Vert with an LS over all of them, but we are talking $$$$$ now) |
09-16-2019, 09:47 AM | #810 | |
Rep 407
Drives: Miss Daisy
N54Yankee2706.00 |
09-16-2019, 10:05 AM | #811 |
2006 TIME Person Of The Year
9720
Rep 6,445
People chomping at the bit for C8 production to begin can't like the news of a UAW strike at GM.
09-16-2019, 10:06 AM | #812 | ||
Rep 282
Blindly believing anything a manufacturers says is very ridiculous. |
09-16-2019, 10:42 AM | #813 | |
BMW Fan
449
Rep 725
This is after driving every version of the Corvette C5-C7 outside of the C7 ZR1. My name is See5 for a reason. |
09-16-2019, 10:56 AM | #814 |
Rep 1,011
