08-16-2009, 10:26 PM | #1 |
Rep 253
Anybody know anything about Ural motorcycles?
08-17-2009, 01:14 PM | #2 |
Rep 274
sure, here ya go
MSRP $9,999 Model Number IMZ-8.1037 Dimensions (LxWxH) mm/inches 2580x1700x1100/101.6 x 66.9 x 43.3 Seat Height mm/inches 813/32 Road Clearance mm/inches 125/4.9 Dry Weight Kg/lbs 320/705 Recommended max cruising speed km/h:mph 105/65 Engine OHV Air-cooled, four-stroke, flat twin cylinder Bore & Stroke 78 & 78 mm Compression Ratio 8.6:1 Displacement 749 cc Rated HP @ 5600 RPM 40 Carburetion Twin KEIHIN L 22 AA Clutch Dry double disk Rated Torque @ 4600 RPM 52 Nm / 38 ft-lbs Alternator 12 Volt/500Watt Starting Electric & Kick-Start Gearbox 4 forward, 1 reverse, shaft drive Fuel 91 Octane Unleaded Tank Capacity liters/gallons 19/5.0 Front Brakes BREMBO with full floating disk Rear Brakes Mechanical Drum Sidecar Brakes Mechanical Drum Ignition Electronic Front Suspension (forks) Leading Link Rear Suspension SACHS Hydraulic spring shock absorbers Wheels Size Front, rear, & sidecar 19" Wheels Type Painted steel, steel spokes, cast alum. hubs Warranty 2 years parts and labor, unlimited mileage Fuel Mileage 26-33 mpg/11-14 km/l* Trunk Volume 2.9 cubic ft/22 gallons Options you may add Second "tractor" seat or bench seat Spare Wheel with Tire Spare Wheel Luggage Rack Tonneau Cover Sidecar windscreen Cylinder Crash Bar Full Size Tool Kit And more… |
08-18-2009, 12:05 PM | #4 |
Rep 2,014
I was really into bikes a few years ago, so everything may have changed. From what I recall these bikes were/are made in an Easter Block Country (former) from old (WW2, BMW) German designs. I don't believe I ever read a good review on them. Simple, so you can work on them, if that is how you enjoy a machine thats great. Unless they have changed a lot I wouldn't buy one.
08-18-2009, 12:13 PM | #5 |
Rep 2,014
I just clicked on your link, not much has changed.
The only reason I would consider buying one is if I really wanted a vintage bike but couldn't find one.....the more that I think about it, I just wouldn't buy one I would find the vintage bike that I wanted. |
08-18-2009, 01:19 PM | #6 |
Nigerian Prince
385
Rep 2,180
Drives: '11 F25
yeah. i used to have 2 back home. one with side car, one without.
great bike, but don't overlook 65 mph top speed....
08-18-2009, 01:57 PM | #7 |
Rep 253
yeah, the top speed has me worried, but this being my first bike, it might be a good thing. I have thought about just buying the HD Iron bike, but I want something a little more one-of-a-kind.
08-18-2009, 08:25 PM | #10 |
Nigerian Prince
385
Rep 2,180
Drives: '11 F25
you can't go wrong with an exact copy of german engineering
agree here. Ural is a little too heavy for the first bike. something in a 250-350cc range would be way better.
