07-16-2016, 10:57 PM | #1 |
![]() ![]() ![]() ![]() 1296
Rep 700
Small engine repair advice needed.
I have a 16hp v-twin lawnmower. Choke linkage works, throttle linkage works also. Spark plugs are new. Engine will not idle or stay running with air filter/box in place. If I cover the carburetor nearly completely and start it, it will run with the choke closed. I can increase the throttle up and down; again only with the carb nearly completely covered. Also at mid-full throttle the governor moves erratically "hunts".
I pulled the carb off and there was some gunk in the float bowl, I cleaned that out and made sure the throttle and choke butterfly's were clean and moved freely. It seems like I'm not getting enough fuel. With nearly no air entering the carb it will stay running, as soon as you unblock the carb or slightly open the choke (even with the carb blocked) the engine dies. My guess at this point is that the main mixture "jet" may have a blockage, therefore not delivering enough fuel. Anyway thanks for your time/advice. |
07-16-2016, 11:02 PM | #2 |
Know's a guy that know's a guy...
5537
Rep 1,902
Buy a bottle of fuel additive, add a couple ounces to a tank.
07-17-2016, 12:14 AM | #4 | |
Rep 2,485
Drives: MW Vespa w/pink racing stripes
(Oh gawd, I remember when 65% of the forum was dedicated to that in 2007-2008) |
07-17-2016, 01:21 AM | #5 | ||
5537
Rep 1,902
07-17-2016, 01:22 AM | #6 | |||
Rep 2,485
07-17-2016, 07:59 AM | #7 |
![]() ![]() 7917
Rep 4,449
If you can't get it working properly try Southern Lawn Equipment near the fairgrounds. They seem to do a good job when my generator needs work.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
07-17-2016, 08:44 AM | #8 |
![]() ![]() ![]() ![]() 2114
Rep 10,180
Sounds like it could be an air/fuel ratio issue, and therefore a carburetor issue. It could be that air is being introduced through a bad seal, o-ring or gasket... Or you are flooding or starving gas due to needles being shot, o-rings messed up or gumming up elsewhere. Since you already took apart the float sand noted gunk, I assume it's not that new, but you are comfortable doing things like that.
Carburators are finicky and if you prefer to take care of it yourself, I would just suggest getting a carburetor rebuild kit from the manufacturer. Otherwise, most small engine repair places do pick-up and drop-off service. |
07-17-2016, 08:57 AM | #9 | |
2nd Asst to Dept Undersecretary
6685
Rep 1,299
Drives: People crazy
I had to do a rebuild on one of mine, but it was a much smaller engine (a pressure sprayer).
This space for rent.
07-17-2016, 09:13 PM | #10 |
![]() ![]() ![]() ![]() 9237
Rep 10,128
My Echo was doing the same thing, and I took it in to get it fixed. It was literally less than $20. Not worth even doing it yourself, unless you simply want to tinker around with it.
07-17-2016, 09:26 PM | #11 |
is probably out riding.
![]() 5962
Rep 2,301
If you're going to use a small engine, make it a 12 cylinder.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
07-18-2016, 12:50 AM | #12 | |
6685
Rep 1,299
07-18-2016, 08:32 AM | #13 | |
![]() 869
Rep 1,260
Today I am treating my gas for all my small engines and recently have been replacing the carbs due poor running issues that have developed over the years. |
07-18-2016, 08:35 AM | #14 | |
![]() 869
Rep 1,260
07-18-2016, 09:03 AM | #15 |
5537
Rep 1,902
OP - when using injector cleaner, it is CRITICAL to remember to only use a small amount or you will damage the internals. Most of the additives are meant for 15+ gallon tanks of fuel, so make sure you are prepared to run a full tank of fuel completely out with the additive if you go this route.
I don't think it's a fuel/air issue. I had a similar issue with a Commercial pressure washer that had sit for about 2 years, the additive solution worked fine. |
07-18-2016, 09:11 AM | #16 |
Baby-faced Assassin
![]() 1198
Rep 152
Drives: when car isn't broke.
The extent of my small engine repair knowledge involves disassembling the intake tract as far as reasonable, followed by generous application of carb cleaner in every orifice until it runs clear, then reassemble.
Little stuff like fuel filters, fuel lines, and o-rings can all be replaced with the spare change you have in your cupholder. Maybe you have a weak spark that's getting blown out? These usually have very simple ignitions, so maybe freshen up the electrical contacts too. |
07-18-2016, 09:19 AM | #17 |
5537
Rep 1,902
Not a lot of science with these engines either. Trial and error has taught me, start with easiest or least expensive/invasive fix first, then work through more difficult/expensive repairs via process of elimination.
07-18-2016, 12:01 PM | #18 |
![]() 5962
Rep 2,301
I use it to power my ePenor.
07-18-2016, 12:04 PM | #19 |
6685
Rep 1,299
And just a V12 works? I woulda thought you'd need that Caddy's 16 cylinder, yo.
07-18-2016, 12:11 PM | #20 | |
![]() 5962
Rep 2,301
07-18-2016, 01:22 PM | #21 |
![]() ![]() ![]() 1618
Rep 14,821
a 16 HP lawnmower....why not hire peasants to not only fix it, but mow the lawn as well? My dad had a 17 HP Kubota, and put it this way, it was bigger than a 328i. We let the peasants deal with it...
07-18-2016, 04:23 PM | #22 |
5537
Rep 1,902
^John - HUGE difference in a 16 hp lawn tractor, and a 17 hp Kubota (Diesel) tractor....just saying
